Just in the process of weighing up my options as to get a spare factory turbo hi flowed or just go for a good second hand GT-RS.
Its going in a R33 sedan, and would like to get about 250-300kwatw.
Any other options i could look into would also be great, and rough prices on hiflowing
https://www.sau.com.au/forums/topic/250558-turbo-options/
Hey mate,
The two options you have listed are really the best turbos for a decent power increase without chasing too high a figures and without having to change much more about the car ie: keeping it looking standard.
A hi-flow on a standard turbo will get you up to around 240rwkw maximum
A HKS GT-RS Kit will get you closer to 260rwkw.
Now be aware that both of these options need some additional mods.
At the minimum you would be looking at upgraded engine management in either the form of a SAFC or Power FC, new fuel pump and if your going over 240kw it would be a good idea to do injectors to (Power FC required). At these power levels the standard clutch would also be towards its limit.
So in answer to your question :cheers:
I personally would go straight to the HKS GT-RS kit. High flows are not exactly cheap and from experience ive learned its best to aim a bit higher and do it right once, the first time. This kit will give you awesome response and great usable street power. You will be thrilled :)
There are some traders on here selling the GT-RS kit for $2800~
To get a standard turbo high flowed by GCG is approx $1600~
Hope this was some help buddy :)
-Dragonforce
https://www.sau.com.au/forums/topic/250558-turbo-options/#findComment-4340711
Thanks for the help guys :(
Was nearly going to buy a good second hand gt-rs but wasn't sure if it would be overkill. The hi-flow question mainly because i have a cactus std neo turbo in need of a rebuild.
Thanks again for the help, much appreciated :)
https://www.sau.com.au/forums/topic/250558-turbo-options/#findComment-4341060
GCG with cams= 260rwkw, brand new turbo. cops wont know its there
where you mentioned a second hand GTRS... and it says HKS on it.
check out the turbo sticky thread and do a search :( some epic threads on GCG's, GTRS's, and the GT30series.
https://www.sau.com.au/forums/topic/250558-turbo-options/#findComment-4342240
What about a GT2871R?
They do a Skyline version of it now at horsepower in a box
Thats what im considering for my turbo upgrade atm. Pretty sure there garretts answer to the HKS GT-RS which i was originally considering
https://www.sau.com.au/forums/topic/250558-turbo-options/#findComment-4342235
Get a hi-Flow with VG30 rear housing, Im aiming for about 260-270rwkw with my auto after I get the rear housing Fitted and retuned with the Vipec.
A guy in sydney is getting 320rwkw from this same turbo in a manual, but I think he is running a forged motor with a few more intake and fuel mods.
https://www.sau.com.au/forums/topic/250558-turbo-options/#findComment-4342566
Yeah that was going to be my question , the GCG Hi Flow with the VG30 0P6 turbine housing .
Internally they are a fair bit bigger than the RB25 housing so with other top end work they are supposed to go well and not have any extra turbine lag .
I'd like to see better wheels in the high flow but I think it may be a case of the small frame GT BB turbine shafts being too small/short and the larger frame GT turbine shafts being too big in diameter .
A .
https://www.sau.com.au/forums/topic/250558-turbo-options/#findComment-4342607
I am currently running the slide hi-flow max over size with the OP6 VG30 rear. The turbo has been excellent with no problems, but it is now time to grab some more power so i will also going the 3076 with the .82 rear. The best power that the hi-flow could get me was 250rwkw. This is at 17psi but when it was bumped up to around 19-20psi the power would drop of so the tuner left it on 17 stating this was the best power curve he could attain. He said this was probably due to the turbo running out of puff up top.
https://www.sau.com.au/forums/topic/250558-turbo-options/#findComment-4342801
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
    • It was picked up on the MOT/Inspection that the offside front wheel bearing had excessive play along with the ball joint. It made sense to do both sides so I sourced a pair of spare IS200 hubs to do the swap. Unfortunately I don't have any photos of the strip down but here's a quick run down. On the back of the hub is a large circular dust cover, using a flat head screw driver and a mallet I prised it off. Underneath will reveal a 32mm hub nut (impact gun recommended). With the hub nut removed the ABS ring can be removed (I ended up using a magnetic pick up tool to help). Next up is to remove the stub axle, this was a little trickier due to limited tools. I tried a 3 leg puller but the gap between the hub and stub axle wasn't enough for the legs to get in and under. Next option was a lump hammer and someone pulling the stub axle at the same time. After a few heavy hits it released. The lower bearing race had seized itself onto the stub axle, which was fine because I was replacing them anyway. With the upper bearing race removed and the grease cleaned off they looked like this The left one looked pristine inside but gave us the most trouble. The right one had some surface rust but came apart in a single hit, figure that out?! I got a local garage to press the new wheel bearings in, reassemble was the opposite and didn't take long at all. Removing the hub itself was simple. Starting with removing the brake caliper, 2x 14mm bolts for the caliper slider and 2x 19mm? for the carrier > hub bolts. I used a cable tie to secure the caliper to the upper arm so it was out of the way, there's a 10mm bolt securing the ABS sensor on. With the brake disc removed from the hub next are the three castle nuts for the upper and lower ball joints and track rod end. Two of these had their own R clip and one split pin. A few hits with the hammer and they're released (I left the castle nuts on by a couple of turns), the track rod ends gave me the most grief and I may have nipped the boots (oops). Fitting is the reversal and is very quick and easy to do. The lower ball joints are held onto the hub by 2x 17mm bolts. The castle nut did increase in socket size to 22mm from memory (this may vary from supplier) The two front tyres weren't in great condition, so I had those replaced with some budget tyres for the time being. I'll be replacing the wheels and tyres in the future, this was to get me on the road without the worry of the police hassling me.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
