jst having to make up some custom cooler piping for my setup, and was wondering if anyone had a good argument for where i should place my bov. atm im slightly confused as my mate has his bov jst after the turbo before the cooler, he does this because he belives it does a better job of protecting the turbo from spining backwards......but if this is true why do you see nissan placing there bov's after the cooler, is that because there plumbing colder air back to the turbo...........or does it not make a difference where she goes.....any ideas guys.. :D
https://www.sau.com.au/forums/topic/250973-bov-before-or-after-fmic/
Ive always run them as close to the throtle body as possible ie 6-8 inches away.
and as for being "better" for the turbo to place the BOV close to the turbo, mmm cant really see how its going to make it better.
what does matter is plumbing wasted air back into the intake pipe after the AFM.
cheers
Turbos NEVER spin backwards. Load of shit. What sort of blow off valve is it? If its aftermarket you might want to hide it down near the cooler so cops dont give you trouble unless you feel the need to show it off. I prefer plumback blow off valves personally and would put it in the stock nissan position unless you have a front facing plenum etc.
Closer to the throttle body you've got the air flowing one direction only, if you put it at the other end you end up with air moving back and forward through the IC, possibly having your colder air in the system reabsorb some of the heat as the pressure drops and becomes less dense.
Suppose with a larger IC it will hold a pretty fair capacity, but keep in mind at 3000 RPM your engine is sucking in over 0.075m3 a sec (150 CFMish), so whatever air sits in the IC will be gone pretty quickly once you get back on throttle. May not matter so much until you're chasing big power/response but if you're going to do it once, closer to the throttle body is likely to do better.
Edited by Hell Fire
ok so after taking all this info in, i've decided that i am placing my BOV before the cooler only because it makes it alot easier to plumb it back. the way i have riged it up is the bov well be in an enclosed box where the air filter is housed keeping under bonnet temps out, also the cooler and air filter piping to the turbo have been wrapped in heat resitant tape, hopefully this well help keep the air going to the turbo fairly dense.... also im sticking with my stock bov , it does a good job , sounds good and is legal too.
Sell the bov.
Many cars out there (street/rally/grip/drift) that run without them and have no reliability issues.
The response gained when running no bov out weighs any driveability or if it concerns you emission negatives.
I've ran 20psi for a good 30k and not one issue.
Prior I had run 100,000km's on the std ceramic turbo @ 1bar and again no issues.
^^ please dont start the 'gain' rubbish.
End of the day, the stock ECU expects a BOV to be there. Emissions also required it.
Using cars that are not street registered and working within the confines of the law are not valid examples
I have a power fc tuned with the blow off valve off as the intake pipe im using at the moment doesnt have an inlet for the plumback. The car runs the same as with the stock ecu in (well for me anyway). It almost stalls when you press the clutch after being in gear at high revs etc. Its also a lot more jerky on gear changes. I have learned to deal with it but it deffinately is different the way the cars drives and ill be putting the bov back on as soon as i can be bothered to make up a new intake pipe.
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
