  • Replies 447
Glad to hear.
Killabeez, check your pm. Yes S13 rear is available.
Musky, the choice for upgrading the rear or not is totally up to you. I had front slotted on my old R33 Gtst and std rear as well. No problems.
Could I please get a quote for Front slotted + Rear slotted rotors and Green EBC pads all round for a R34 GTT? Ship to Adelaide. Thanks.
gday mate
um ive got an r34 gtt
wondering how much all up to get Grooved Dimpled on the front and standard slotted on the back both with pads will be sent to adelaide, 5108
thanks mate
oh thats a decent price um when will the next groupe buy be after that one mate?
um brakes not really in this months budget
no problems
next group buy some time in early July.
if you go to My Controls, upper RH corner, then on the left sidebar go to Board Settings, make sure the "Disable Personal Messenger" section is set to No.
Setting it to Yes will disable your personal messenger.
if still doesn't work, email me: rsoputro at hotmail dot com
(replace the obvious words above with the proper symbols, you know the drill - spam prevention)
i'll send you a quote soon.
Hey bud, after current pricing on front slotted; and for both plain and slotted for rear rotors. To suit R33 GTS-t. Delivery to 4108.
Cheers
Edited by N-DAWG
Hi, is there anyone online who can tell me in the next 5 minutes how the hell to get the rear rotors off an R34GTT? Otherwise I am taking to it with a slegehammer. I assume the handbrake assembly is inside the top hat and I somehow have to undo that? Please help ASAP. I have the car in 1,000,000 pieces right now and want to get it back together.
release handbrake. handbrake drums might be pressing the inner drum of the rotors, making it too tight to remove.
it can get sticky, from all those age old rust and dirt and grime get stuck in between. use rubber mallet. sledgehammer is a bit extreme... :-)
Yeah I released the handbrake. So there are definitely no other nuts/bolts to remove once the brake caliper is off? Just bash the bit of the disk you can see? Trouble is with the shield around it there is not much room to swing or hit.
Damn - might jack it up as high as it will go and get some leverage on the mallet. Thanks! It doesn't seem to have much movement at all - I take it it will gradually loosen up and come off?
Well I have just finished putting it all back together.
In the end I gave up on the getting the rear rotors off - making the necessary noise at 11pm seems like a bad idea in my neighbourhood.
So, today I did:
- Fitted front RDA slotted/passivated rotors
- Fitted front QFM HPX pads
- Fitted front and rear ADR compliant braided brake lines
- Flushed entire brake system with Motul Dot5 and refilled/bled
- Painted all calipers gold
Phew - 9.5 hours all up.
The result is below
    • The real question is, on some of those wild roads they call highways, how many times did a farmer in an old ute from the early 2000s blaze past you over double lines?   Tassie is a wild and really cool place, and after doing a work related road trip there January of 24, I understand why Targa Tasmania is ran there, and is so tough to do well at! We had a brand new Camry Hybrid that handled quite nicely, and thankfully weren't in an old car, because cresting some of those hills in a 100kmh zone for it to suddenly be like "surprise f**kers, this is a recommended 30kmh hard right turn" wouldn't be pretty. We weren't racing the Camry around, but we weren't slouching in the bends either. But my lord those old farmers know their old clapped out utes, and those roads, as they were absolutely hammering it!   You're also super lucky to make it up to Mt Wellingtong this time of year. It's often road closed with snow/ice! Also, I hope you hit up Salamander Road in Hobart for some insanely good food (I highly recommend the dimly lit Irish pub for a Guiness Pie, or even the bangers and mash!!!)   How long did the Ferry take to get across? I want to do a road trip of Tas on my own time, but I get horrifically sea sick, and I don't want me on the Ferry, just the car 😛
    • So far so good, about 30km on it so far and nothing out of sorts yet thankfully
    • Look at @Kinkstaah's thread on the issue.
    • Hmm not really, I'd say its race car life or modified car life when you make 3 or 4 times the power Nissan designed the car for lol.
    • I'll let others with more breakage chime in, but I can't think of anyone who had a problem with the standard centre plate before they had a problem with the standard gears - the plate generally just gets replaced for safety when the gearset is upgraded. As for the gearsets, its not like they are OK at 600Nm and break at 601. Their longevity is a combination of how much torque you are making and how gentle you are on shifts (or not).
