  • Replies 74
...if it rains i put the roof up on the zed i guess
or wear a raincoat :P
seriously though- this is not the same as a sprint or a track day
it's the closest you will get to door to door racing in a relatively tame environment - but like everything that happens on the track there is a risk
and this is still racing, so unless you're prepared to be up close and personal with other cars you might want to look at other events
hahha
liar
sounds like a bit of fun
I'm consistantly slow lol. bit handy huh!
not at all, competing with pete was a real honour. I've never seen anyone perform a drunken fall off a balcony onto a collectable car with as much skill as him.
Give me a call before the event Pete. I probably wont enter but I can bring a spanner down. god knows you r31 boys would need one.
  • 1 month later...
whats the go guys, havent heard much in the last month. Are you all set, what time is everything happening?
yea have 5 31's and one 240z
be lucky to make 3 hours
lol
all help appreciated
especially if you have massive tits (eg duncan)
HI everyone, unfortunately it didn't go ahead, lots of people were keen to enter but that didn't equate to entries. Once a date is decided for 2010 it will most certainly be announced and we will be working hard to ensure the event is a success in 2010. Meanwhile there is a 6 hour at Winton if anyone wants to have a crack at that!
    • Yes, I had ordered the spherical bushings at the same time as the rest. I have high hopes for the anti squat reduction kit.
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
