  • Replies 74
...if it rains i put the roof up on the zed i guess
or wear a raincoat :P
seriously though- this is not the same as a sprint or a track day
it's the closest you will get to door to door racing in a relatively tame environment - but like everything that happens on the track there is a risk
and this is still racing, so unless you're prepared to be up close and personal with other cars you might want to look at other events
hahha
liar
sounds like a bit of fun
I'm consistantly slow lol. bit handy huh!
not at all, competing with pete was a real honour. I've never seen anyone perform a drunken fall off a balcony onto a collectable car with as much skill as him.
Give me a call before the event Pete. I probably wont enter but I can bring a spanner down. god knows you r31 boys would need one.
  • 1 month later...
whats the go guys, havent heard much in the last month. Are you all set, what time is everything happening?
yea have 5 31's and one 240z
be lucky to make 3 hours
lol
all help appreciated
especially if you have massive tits (eg duncan)
HI everyone, unfortunately it didn't go ahead, lots of people were keen to enter but that didn't equate to entries. Once a date is decided for 2010 it will most certainly be announced and we will be working hard to ensure the event is a success in 2010. Meanwhile there is a 6 hour at Winton if anyone wants to have a crack at that!
