  • 9 months later...
On 1/16/2009 at 9:05 PM, psi said:
Now for a few more pics..
the pink filled bit in the cam journal is where the oil is fed into the bearing (that now comes from my new mod), and the Green bit is where the oil is fed to the VVT..
The pink circle is where the new plug will be inserted.
The brass plug is the return oil passage from the VVT solenoid to the head.. not much exciting in there, but I just wanted to look in there!
I bought a 25/30 and i dont think this has been done to the engine. It hasnt been driven for too long so hopefully the damage isnt too much. Im going to be swapping the heads soon anyway. So is this as simple as removing the plug and drilling it from the back then across halfway?
The pink and the green holes. Did you have to drill any of those out? Im asking as Im avoiding the scenario where I have to remove the cams. Can this be done without removing the cams? When I fit the brass plug back in does the perpendicular hole have to line up with the pink hole?
  • 1 month later...
Interested to know from anyone who has used the TLG VCT kit posted here. It seems like it would work but I’m very sceptical. Maybe someone could explain how they think this would address the oil problem. It has an alloy block that removes the VCT solenoid from the head and relocates it to the right hand side of the engine, right under the oil pressure sender unit.
So the oil supply to the alloy block is Tee'd from the oil pressure sender. Then it goes from the alloy block to the original location for the VCT solenoid. My question is how does this trigger the normal operation of the VCT gear. What stops the oil flowing back into the engine block if there is too much resistance on the supply side. It seems like the external oil feed has been used quite a bit but from the search I’ve done. I cannot see how the VCT is activated using this method. Also noticed that the VCT solenoid had a second o ring the bore on the TLG doesn't seem to be using this.
Bryce I'm currently using this kit. I have to pre-warn you though and tell you that the creator is not very transparent, it took me almost 3 months from payment to receiving the product. Told me that his machinist was giving him the run around, and it wasn't until the machinist messaged me personally that I received the whole picture and not the one side. He takes the orders before even telling his machinist to make the kits and does not keep large stock of them in advance.
NOW, this kit is fantastic... I currently use it on mine with an RB25 Neo head with an RB26 block. The unit takes its feed from the pressurised oil in the side of the block, and the solenoid then turns on or off and allows oil to flow into the head. The piece that gets screwed into the head is like a dummy VCT Solenoid, and sends oil into the correct port and then up into the VCT Gear.
The kit was pretty damn easy to install and I'd say pretty discrete as well. I had actually tapped a hole in the front of the head because I didn't realise this was an option, instead welded that back over and went with this kit and happy I did.
  • Like 1
This is how i did mine. You cant even see it with the manifold on an retained the vvt sensor in std location and is fed from the same location off the side of the block/original rb30 pressure sensor hole. I also retained the 25 neo oil cooler. This wayit looks stock.
  • Like 1
Very accurate. I'm buying the kit off a mate.It took him more than a month to get his stuff.So I'll just buy it off him. Have you guys checked to verify that VCT is engaging?
I can physically feel the VCT engaging, VERY noticeable difference in torque with the VCT plugged in.
I use this controller to tell it when to turn off and on.
http://www.nzefi.com/product/variable-cam-timing-vct-controller-r33-rb25det/
  • Like 1
  • 7 years later...
So these external kits with the machined block for remote solenoid mount will only work on a NEO head and RB30 or RB26 bottom end
For an R33 head on a 26 bottom end the remote vct kit is to resolve RB26 manifold adaptor plates etc  IF you try to use the remote VCT on an RB30 or RB26 bottom end with an R33 head then  you can starve the cam journal???
I have one of these kits from bits I had years ago before plans changed
I don't understand how that tracks with this video
https://youtu.be/RuPiI22Mplk?feature=shared
This looks like I can run the v termite vct kit to feed the VCT on an R33 head on an RB26 bottom end?!?!?
Lol.... don't v have these problems on RB20s :)
    • I was using the wiring diagram I have So 12.74V is coming into the rear Fuel Pump relay as I measured.  When I turn the key to ON im getting 0.6V to the Fuel Pump plug; which i assume is backfeed voltage and doesnt include the 12V from ignition power.  The rear relay is working and being triggered.  From the diagram I clearly see the rear relay 80 = Rear Relay going into the Body/H loom (R-27) 27 = Fuel Pump plug going into the Body/H loom (T-20) 40 = Short Connector (R-27) I'm reading 12.74V on the blue/black wire which is the power for the Fuel Pump   From this diagram I can see the Ignition relay goes into the front and up to the ignition  2 = Fuel Pump Relay <1M> (R-27) 37 = ING Relay <1M> I started from the pump using this reference Which the way I read it (referencing Nissan wiring color codes) is: Pin Wire Color Function 1 B/P (Black/Pink) Ground 2 L/W (Blue/White)        ECU Trigger 3 SB (Sky Blue) Fuel Pump 5 L/B (Blue/Black) 12V Constant Tested SB to SB on Fuel Pump for continuity - confirmed Tested negative on Fuel Pump to 12V battery and L/B - confirmed 12V Pulled the relay putting 12V between Pin 1 & 2 and testing continuity on Pin 3 & 4 - confirmed relay   So that has me looking at this part of the circuit to understand whats happening here...and im still confused. From best I can tell; the disconnect is back to my previous diagram; between Ignition Relay and Fuel Pump Relay...which yet again; afaik is where the immobiliser should.    Thats what I was trying to explain to GTSboy; im not trying to fix it myself; yet I seem to have to get a Masters in Electrical Engineering (while im busy doing my actual job of DevOps & Cloud Engineering) somehow.  I just wanted more expert opinions; or more so that what I tested is correct and proves it to something around that area; to go back to the alarm tech (for a 3rd time) that he needs to fix it. He keeps telling me its not the alarm. He lives on the complete other side of the city so i understand not wanting to make a trip but as I said before if its the alarm it should be up to him to fix it. But he's adament its not; even though I pointed out the FP was immobilised through the original alarm. To my mind; it seems that the ECU is sending the signal; but the ignition is not getting 12V down the line.
    • Maybe also really stiffly sprung track cars. Get the inside wheel up in a corner and all the fun stops. Also me sometimes (rarely) when I have to stand on the brake to convince the diff to drive the wheel that is still on the ground when I'm trying to diagonally get over severe driveway entrance, etc.
    • I feel like I'm missing something. You had an authorised installer come out and install a new alarm. Post install the car doesn't start, and you aren't getting the installer back to fix what they did wrong?
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
