I was more refering to the rapidly expanding gas and the huge heat shock it would cause, like a 600-700deg exhasust manifold and then spray some cold water into it
Edit - oops still signed in to Prues account lol
Zebra
Ahh ok, I was getting mixed up with an old engine idea of injecting water in with the fuel to keep engine temperatures down: barely any combustion energy is lost due to the expansion of the liquid water and wouldn't affect the exhaust as it would be at temperature.
You're right though, it'd only do damage after the pistons
Sorry for the late reply haha.
I have a few graphs to show the difference between E85 and PULP 98. Same car, same dyno, same night, same tuner.
PULP 98 VS E85 Same boost.
As tuned
Basic spec list is:
GT block
Tomei 2.8 (9.0 compression)
270 @ 10.25 cams
ported head
HKS GT RS's
HKS dumps and front pipes
kakimoto full mega N1 cat back
Power FC
ID 2000 cc injectors, Nismo lift pump and 2 bosch 044's feeding the engine
+ all the bullcrap to support it.
The midrange improvement on E85 is amazing! Once it comes on the tacho just flicks to the limiter. RWD is quite fun!
well done, crazy results...
Gosford caltex is doing tank works at the moment which means yeeeeehhaaaaaa E85 will be in my tank soon :action-smiley-069:
Was a little bummed at the final figure to be honest.
Its funny... My last tune on the same dyno before the ARC cooler went on was 370 rwkw on 98... and this time I didnt crack the 350 mark. Bit strange.... They have changed dyno's though.. maybe that has something to do with it. Either way it feels 461946129649% better on E85. The throttle response is amazing. It almost knows what your going to do before you do anything with your right foot!
Are you sure they've changed dynos?
Not a bad figure there... What were you expecting it to make before going E85?
Congratulations on the result. What exhaust manifolds are you running?
Usual variance is you say +/- 15rwkw, fits into it though whether they have/have not changed it :D
The 350rwkw run you are only running just over 22psi (or so??)
The final 416rwkw run is 25-27psi. Boost + fuel have given the result there don't forget.
GT-RS's on 20-22psi aren't doing much anyway. You really do need to get 25-30psi into it and hence the 416 run has seen a nice solid punch when combined with the E85
The gains are quite good as it comes up onto boost in the midrange. Not surprised at all you notice it, RWD surely has to be pointless :action-smiley-069:
Although overall, the end result is nothing that -5/2530's can't do (power vs boost wise), with better response...
Yeah they have.... only had it a few months I think
I was hoping around the mid 400's. As you can see the difference between 1.7 bar and 2.0 bar netted an extra 12 kw. Yavuz reckons its the exhaust housings and the exhaust choking it up a tad. Hmmmm i dunno
Tomei Expreme.
Yeah the midrange is what I was hoping to really gain out of this. As we all know GTR's have sweet FA under 4K anyway (unless you have a dirty 30.... which one day I will have haha).
Ash there are times which I had the 2530's hanging off the side of mine, Esp with the OS 5 speed sometimes you just cant carry that much speed into slow corners..... this is where a 6 speed would really shine! Get her onto a fast flowing track like Eastern Creek and thats where it would love it! But lets be honest... I aint changing turbo's. Effort, time and money. 600 HP road car is enough for most people yeah? lol
Ha. Spinning the rears at 140 in second (OS 5 speed) in the dry is hell fun! haha
hehe gotta love the extra bit of length the OS gives :action-smiley-069:
It does indeed depend on what you are doing and the setup of course :D
Was just musing on it as i have with Steve-o a couple of times of late about -10/RSs vs -5/2530s
Oh indeed – having a ponder on the throne just then.
I too wonder if there is an exhaust restriction... easy way to be checking that one :D
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
