is that 3rd gear paul? awesome results mate...all that bullcrap to support your fuel system LOOOOOL
Nah mate second.
at 8000 RPM with 4.111 diffs (stock)
1st = 87
2nd = 138
3rd = 190
4th = stock (1:1)
5th is shorter at 290 but i stuck with the stock gear which goes to 310
Another problem is the CAS. Both Steve and I have developed Crank Angle Sensor noise above a certain RPM.... So basically you cant be 100% accurate with the timing up in the rev range. I was warned about this before this tune and was hoping it wouldnt come up.... but it did. Now in all my years of scratching around on SAU and the pommie forum I have never seen a thread discussing this issue. Has anyone else come across this and if so why isnt it common knowledge!?!?! There is a fix... a balancer trigger... but thats expensive and to be honest I really cant be arsed........ thats what I said 2 years ago! haha
Yavuz says it's from the belt flopping or shaking at such high rpm. We are only talking 7000rpm plus. So for most people it doesn't matter, bit the people in this thread clearly aren't "most" people :action-smiley-069:
Yes it's a common problem but usually easily fixed by fitting a dual pulse disc in the CAS.
Don't remember it being more than $100 and when your engine blows you'll kick yourself. Either that or you'll see your timing walk around 10-15 degrees in the top end and that'll be enough for you to make the decision to fix it
Paul it's discussed in this thread from GTROC
http://www.gtr.co.uk/forum/52458-rb30-engi...ts-pics-12.html
Starts on page 12.
Mark
Would that be the same mod to the CAS that needs to be done to run an autronic known as a slipper disc?
What is it like driving a car that takes until 5k before the power really kicks hard? Is it annoying on the street or is there still plenty of meat below 5k? Looks like a solid 200kw at 4k, does it feel good at the lower revs?
Edited by Rolls
    • Why are people so insistent on making dirty water?!
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
