Twin Nismo's intank!!!
I too prefer in tank setups...I've had an external setup with 3x044's and its just sooo much neater when u can't see it, besides that, u can tell the police the car is stock with just an exhaust :)
Btw Dean, I watched your footage in your sig and it is a very nice gtr. The white wheels set it off!!! Is this Matt's old nusmo gtr? Looks very familiar.
This is what I am going to use.
An 'intank' pump of sorts but in a surge tank. Single pump only, (so hopefully reducing the possibility of one pump failure causing the other to run out of legs and lean the engine)
Being submerged, I hope this will be a better environment for the pump, neater solution. (less connectors / lines etc) Includes the pre-filter.
Additionally I'll run a speed controller for it, so at idle it will only tick over. Then run mid duty up until boost comes on at which point I'll run it flat chat.
Hopefully this keeps the noise down, the heat down and extends the pump life.
Ya realz
As long as you are only going to highway race. Any limiter launches or hard cornering may cause it to suck air and blow your engine
Hasn't been a problem for my Nismo in tank...
Even on the bank of the Thunderdome at full noise (25 degree angle), was fine.
haha! errr yeah... well when its 'banked' that much your fuel is kinda kept at the bottom of the tank isn't it? Perhaps not the best example..
Fill a bottle 1/4, tip a bottle 25 degree's and then spin in a wide circular fashion - Not a perfect showing, but the water doesn't exactly sit on the bottom. Then add 200km/h and a bumpy surface for shits & giggles...
I've also done what... Maybe 100-150 limiter launches?
Then there are the cars with 380-400rwkw that run around Philip Island, on semi comps, with in-tank's and no failures.
Properly mounted that aren't a problem that anyone down here has been on the bad end of.
turbine pumps are the go, but they are designed to be always submerged, ive been on the dyno alot latley and the roller cell pumps, mainly 044 seem to have a really bad tolerance to the temp of the fuel, ie tuned all good then as soon as the fuel is hot they drop pressue, and you have a 350kw engine running 13:1 afr's....
Whoa ease up there partner.. Not saying the nismo won't do the numbers, just pointing out your example of a 25 degree bank doesn't make your point very well as it reduces the problem, doesnt make it worse now does it.
Actually. Fill your bottle 1/4 full and swing it in a wide arc ( at the right speed) and it will sit on the bottom.
Taking corners at Philip Island is a much better example.
You er, drinking anything tonight Ash?
I went googling to find out more about this and came across this pump which I haven't seen before.. apologies if this is old news, but has anyone used/seen one of these?
http://www.bosch-motorsport.com/en-US/literature/en-US/B261205366-01_DataSheet_enUS_T7398978443.pdf
Huh? Was just providing information/examples... :ermm:
I really cannot see how it's going to sit perfectly on the bottom with g forces you can feel heavily and 25 degree angles and the fuel is being pushed to the side, not bottom, in such a situation.
Just so we're on the same page..
Lets say the corner we are talking about is a left hander. So you, the driver, are sitting on the high side of this bank, doing circa 200km/hr. Which way side of the tank is it that you think the fuel is being pushed to?
Gravity is trying to pull the fuel down to the left side of the tank. That's where it would be sitting if your car were parked still on that slope facing the direction of the corner.
When you are turning hard left on the FLAT bit of road, the fuel makes its way to the right side of the tank.. agreed?
On the bank, while turning left at 200-250km/hr, the fuel will 'climb' back up to be approximately flat on the bottom of the tank - negating the force of gravity pulling it down. Yes, of course it won't be 'perfectly flat', but its not perfectly flat doing 200km/hr on the flat straight bit of road either. (but I didn't say 'perfectly' to begin with) Also it will vary depending on whether you are doing 180km/hr or 220km/hr, so lets not split hairs. If 200 happens to be the sweet spot, then the differences will only be like taking that corner at 20-40km/hr.. ie, not nearly as much fuel movement as you think. Hence just not a good example for what you were trying to say. That is all.
Grab that bucket from the laundry, put 3 inches of water in it. Go outside (that's an important step), hold the bucket out at an angle and start to rotate - watch what happens and get back to us.
also! Make sure you get someone to take video - not for any scientific value - I just think it will be amusing when you stop.
Remember this is why the corner is banked the first place, to negate the lateral G forces - on the tyres mostly - but same result for the fuel.
Seen the exact same issue with aeromotive pumps when they heat up too.
Come to think of it, I had the same problem when I took my car for a 3 hour drive and the exhaust light flashed on my dash at the time. It was leaning out and must have been due to the warm fuel and bad tolerance 044's.
Does anyone have a cross section image or detail of the gtr tank as I've been informed that the r32 tank is well baffled. I've always wanted to what it looks like inside...
Interesting.
I've driven my car from Sydney to Shepparton with the 2 044's going flat out the whole time and no issues. I have a Fuel pressure gauge on my steering column and that was solid as a rock.
Interesting.
Cruise speeds mean lighter loads and less fuel pressure. Less load on the pumps, allowing them to operate without generating as much heat.
All your extra plumbing and surge tank will help eliminate heat from the fuel system as well to a degree, but ideally you would have a cooler on the return line. It would be interesting to see what your fuel temps are after sustained operation at high loads when the pumps are really working.
The big bosch pumps get noisier when they start to cavitate as they boil the fuel. You won't notice this as much with two pumps as its partner makes up the shortfall in flow when this starts to happen.
Interesting.
i wonder if my rubber return line had anything to do with this which ran from the engine to the boot, as rubber would be a better heater insulator than a steel hose line?
i agree that extra lines would provide cooling properties to a small degree, although, my surge tank was mounted in the boot (very little ventilation) & i was very surprised with how warm the surge tank would become after a decent run. i no longer have that car so its no longer my problem (the surge tank ended up in a 900hp supercharged 67 mustang)
Ian, you bring up a good point there. My surge tank is underneath the car so maybe that airflow over the whole setup brings the temps down enough? I should measure the temp of the fuel after a session at a trackday. Dont forget at idle speeds (and light loads) with the pumps not being switched they would be moving alot of fuel in and out of the engine bay, heating up a little every 'round trip'.
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
    • So, what else.... Power. I don't know what it is making because I haven't done a post tune dyno run yet; I will when I get a chance. It was 240rwkw dead stock. Conclusion from the day....it does not need a single kw more until I sort some other stuff. It comes on so hard that I could hear the twin N1 turbos on the R32 crying, and I just can't use what it has around a tight track with the current setup. Brakes. They are perfect. Hit them hard all day and they never felt like having an issue; you can see in the video we were making ground on much lighter cars on better tyres under brakes. They are standard (red sport) calipers, standard size discs in DBA5000 2 piece, Winmax pads and Motul RBF600 fluid, all from Matty at Racebrakes Sydney. Keeping in mind the car is more powerful than my R32 and weighs 1680, he clearly knows his shit. Suspension. This is one of the first areas I need to change. It has electronically controlled dampers from factory, but everything is just way too soft for track work even on the hardest setting (it is nice when hustling on country roads though). In particular it rolls into oversteer mid corner and pitches too much under hard braking so it becomes unstable eg in the turn 1 kink I need to brake early, turn through the kink then brake again so I don't pirouette like an AE86. I need to get some decent shocks with matched springs and sway bars ASAP, even if it is just a v1 setup until I work out a proper race/rally setup later. Tyres. I am running Yoko A052 in 235/45/18 all round, because that was what I could get in approximately the right height on wheels I had in the shed (Rays/Nismo 18x8 off the old Leaf actually!). As track tyres they are pretty poor; I note GTSBoy recently posted a porker comparo video including them where they were about the same as AD09.....that is nothing like a top line track tyre. I'll start getting that sorted but realistically I should get proper sized wheels first (likely 9.5 +38 front and 11 +55 at the rear, so a custom order, and I can't rotate them like the R32), then work out what the best tyre option is. BTW on that, Targa Tas had gone to road tyres instead of semi slicks now so that is a whole other world of choices to sort. Diff. This is the other thing that urgently needs to be addressed. It left massive 1s out of the fish hook all day, even when I was trying not too (you can also hear it reving on the video, and see the RPM rising too fast compared to speed in the data). It has an open diff that Infiniti optimistically called a B-LSD for "Brake Limited Slip Diff". It does good straight line standing start 11s but it is woeful on the track. Nismo seem to make a 2 way for it.
    • Also, I logged some data from the ECU for each session (mostly oil pressures and various temps, but also speed, revs etc, can't believe I forgot accelerator position). The Ecutek data loads nicely to datazap, I got good data from sessions 2, 3 and 4: https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-2?log=0&data=7 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-3?log=0&data=6 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-4?log=0&data=6 Each session is cut into 3 files but loaded together, you can change between them in the top left. As the test sessions are mostly about the car, not me, I basically start by checking the oil pressure (good, or at least consistent all day). These have an electrically controlled oil pump which targets 25psi(!) at low load and 50 at high. I'm running a much thicker oil than recommended by nissan (they said 0w20, I'm running 10w40) so its a little higher. The main thing is that it doesn't drop too far, eg in the long left hand fish hook, or under brakes so I know I'm not getting oil surge. Good start. Then Oil and Coolant temp, plus intercooler and intake temps, like this: Keeping in mind ambient was about 5o at session 2, I'd say the oil temp is good. The coolant temp as OK but a big worry for hot days (it was getting to 110 back in Feb when it was 35o) so I need to keep addressing that. The water to air intercooler is working totally backwards where we get 5o air in the intake, squish/warm it in the turbos (unknown temp) then run it through the intercoolers which are say 65o max in this case, then the result is 20o air into the engine......the day was too atypical to draw a conclusion on that I think, in the united states of freedom they do a lot of upsizing the intercooler and heat exchanger cores to get those temps down but they were OK this time. The other interesting (but not concerning) part for me was the turbo speed vs boost graph: I circled an example from the main straight. With the tune boost peaks at around 18psi but it deliberately drops to about 14psi at redline because the turbos are tiny - they choke at high revs and just create more heat than power if you run them hard all the way. But you can also see the turbo speed at the same time; it raises from about 180,000rpm to 210,000rpm which the boost falls....imagine the turbine speed if they held 18psi to redline. The wastegates are electrically controlled so there is a heap of logic about boost target, actual boost, delta etc etc but it all seems to work well
    • hahah when youtube subscribers are faster than my updates here. Yes some vid from the day is up, here:  Note that as with all track day videos it is boring watching after the bloopers at the start.  The off was a genuine surprise to me, I've literally done a thousand laps around the place and I've never had instability there; basically it rolled into oversteer, slipped, gripped and spat me out. On the way off I mowed down one of the instructor's cones and it sat there all day looking at me with accusing cone eyes as I drove past. 1:13:20 was my fastest lap, and it was in the second session, 3rd lap.  It (or me!) got slower throughout the day as it got hotter.
