So blunt... Love it
Btw my GTR hasn't been run in 4weeks stevo feel freeto take it for a spin...
NO LAUNCHES!
Damn that edited bit haha
Yeah ok sweet man thanks, I'll ring dopey and organise to drive it around for a couple of hours for you. Hurry up and get back from the sticks lol
Run the risk of ending up with a single injector flowing 7% extra at low duty cycles. ID weed out this problem.
Bosch have a factory difference of less than 2%, perhaps the cheapest option is to ask Aznew (Injectorsonline) the Aus wholesalers to match flow a set for you if your'e worried? It would be worth paying extra for it, you would still be miles in front. $250 each is a joke.
http://www.injectorsonline.com/indivprod.php?cid=106&scid=41
Iv had both and now run genuine ID after having the above problem with the Bosch.
Or you could all stop falling for the sales hype and buy genuine bosch injectors.
And before you think you are going to reply with all kinds of flow matched this and dead time tested that, crap, it's bullshit. We've had two brand new sets of genuine ID's not work straight out of the packet.
ALL INJECTORS should be flow matched precisely 5 minutes before you put them in and start the car for the first time.
and EFI Performance do all our dead time testing at the same time.
Don't forget the volume of injectors ID would roll through we're talking 1000's of sets by now not 20-50 how many injectors like the faulty one i had would they have found?? Just takes a few people having problems like I did and your rep goes down. What were the problems you had with the ID injectors?? ID are pretty good to deal with when the new 1600's came out I jumped on them but after people started having lean out issues due to a inherent injector issues ID replaced and upgraded me to 2000's and paid for shipping both directions. Pretty good service I thought. Did your Bosch dealer do the same?
well said dan with regards to peoples perception and flow testing.
I have dealt with efi performance as well, very knowledgeable when it comes to fuel mgmt
We only used two sets, both times the car wouldn't start. We had to run them through the injector bath twice before they came up good.
We had the same with a Bosch injector once also. That's why we clean all injectors before use now. They aren't bad injectors. Not a single injector on this planet can be cleaned and flowed, then sit for a month and still have its company guarantee its perfection.
We've never had lean out issues with the pencil type 1600's.
Any time we've had an injector issue with a Bosch injector (ID's included) they were fixed with a clean so we never had to return any.
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
