So blunt... Love it
Btw my GTR hasn't been run in 4weeks stevo feel freeto take it for a spin...
NO LAUNCHES!
Damn that edited bit haha
Yeah ok sweet man thanks, I'll ring dopey and organise to drive it around for a couple of hours for you. Hurry up and get back from the sticks lol
Run the risk of ending up with a single injector flowing 7% extra at low duty cycles. ID weed out this problem.
Bosch have a factory difference of less than 2%, perhaps the cheapest option is to ask Aznew (Injectorsonline) the Aus wholesalers to match flow a set for you if your'e worried? It would be worth paying extra for it, you would still be miles in front. $250 each is a joke.
http://www.injectorsonline.com/indivprod.php?cid=106&scid=41
Iv had both and now run genuine ID after having the above problem with the Bosch.
Or you could all stop falling for the sales hype and buy genuine bosch injectors.
And before you think you are going to reply with all kinds of flow matched this and dead time tested that, crap, it's bullshit. We've had two brand new sets of genuine ID's not work straight out of the packet.
ALL INJECTORS should be flow matched precisely 5 minutes before you put them in and start the car for the first time.
and EFI Performance do all our dead time testing at the same time.
Don't forget the volume of injectors ID would roll through we're talking 1000's of sets by now not 20-50 how many injectors like the faulty one i had would they have found?? Just takes a few people having problems like I did and your rep goes down. What were the problems you had with the ID injectors?? ID are pretty good to deal with when the new 1600's came out I jumped on them but after people started having lean out issues due to a inherent injector issues ID replaced and upgraded me to 2000's and paid for shipping both directions. Pretty good service I thought. Did your Bosch dealer do the same?
well said dan with regards to peoples perception and flow testing.
I have dealt with efi performance as well, very knowledgeable when it comes to fuel mgmt
We only used two sets, both times the car wouldn't start. We had to run them through the injector bath twice before they came up good.
We had the same with a Bosch injector once also. That's why we clean all injectors before use now. They aren't bad injectors. Not a single injector on this planet can be cleaned and flowed, then sit for a month and still have its company guarantee its perfection.
We've never had lean out issues with the pencil type 1600's.
Any time we've had an injector issue with a Bosch injector (ID's included) they were fixed with a clean so we never had to return any.
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
