Did a firmware upgrade on the vipec that solved the misfire problem i was having a few pages back.
Went back for another tune it made 486rwkw on e85. Engine is rb26, -5's running 26 psi
Can any tech heads tell me how to upload the dyno graph as its over 2mb ??
Edited by Mark-32
I'll PM you my email and i'll do it for you if you aren't sure how to
Or, you can sign up with a hosting place like photobucket and host it there then use the IMG tags to embed into this thread
EDIT: Here they are
that is a huge number for -5's even on e85....
keen to know spec list too
I was suprised myself but I have dyno papers from when it was first run in on dyno on 14psi, then tuned on 21 psi on pump fuel, then now on E85.
All the dyno runs today were in 5th gear as 4th would just bag the tyres.
Spec list of what i can remember in no particular order is-
RWD Rb26 conversion in an r32gtst
r33 5 speed
hi octane 11 litre sump (rear head drain, nismo oil air seperator going into main catch can that drains to sump.)
1mm restrictor
2860 -5s
big trust intercooler (unsure of exact dimensions but its over 100mm thick and pretty huge)
exhaust is stainless split dumps into 3 inch y pipes into a 3.5 inch sidepipe no mufflers
cams are tomei 260 10.8mm lift??
nitto/je pistons
nitto I beam Rods
Arp stud kits throughout
balanced and blueprinted
nitto 1.2mm head gasket
vipec v44 ecu internal boost controlled
fuel system is 1v 044 lift pump
2x 044 external out of surge tank feeding hicas lines
greddy twin entry rail
aeromotive fuel reg
ID1000 injectors
Edited by Mark-32
Eyebrow's are raised by that result... Seems to be a bit on the generous side?!?
What would correction ratio be between AT 9deg and IT 21deg?
+1
With probably the strangest boost curve ever... And -5s hold 26psi @ 8000rpm without any drop off in torque!?!
This is certainly odd.
I assumed the figure was so high as its rwd only?
To begin with the boost was at 24psi but the boost curve flattened off aswel as the power curve around 6500rpm making consistant 430 odd rwkw.
The tuner asked if i was happy with that and I said i wanted to add a litte more boost at the end of the rev range to see if the power curve would continue upwards in the direction it was heading. He then snuck more boost into the engine up top and thats what happened.
Im stoked with it, haters are guna hate either way but it is what it is.
  • Like 1
The tuner said it was cylinder pressure that would kill the engine and it seemed as though it was struggling for spark as you can see from the dip in the power curve that looks like wheelspin after 5500.
The tuner had to adjust the boost controller in that way so it would run properly.
I have a crappy photo of the dyno screen from where he was adding more boost. It went 420 on 21ish then 460 odd on 24+ then made 486 up to 26psi
I just dont know how to upload it as its over 2mb. I can send it to someone if they can do it for me?
    • That is surely the biggest gathering of Stageas in North America, ever!
    • Remember kids - if you can't afford to buy 2 GTRs......
    • I know people cry at the price of the Getrag 12-14k for a conversion now, but it really is a nice mid point. Not going to get change from 10k on a gearset installed.  $30k++ for sequential.   I know you run the risk of a damaged used one and parts are hard to get but as a street car gearbox its really hard to beat. If you enjoy a more traditional manual, its the choice no question.
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
