Hey all,
Well last night i got my video camera back from a mate so me and my best friend george decided to go to some private roads (those ones i showed u slip). And get a bit of footage. We tryed a few different places and gained some great footage. Final drift of the night and im about to pull over, but decided to try this one corner in revers thinkin it would be the same. Well to cut a long story short it was OVERSTEER, DRIFT, OVERCORRECT, GUTTER, FRAGMENTS OF MY FRONT LEFT MAG IN MY FACE. I hopped out of the car histerical! Kicking it screaming yelling and what not then calmed down and tryed to think of story to tell dad. Then i thought **** it ill just leave it at home and go to a mates house so i did. I didnt get a chance to check the car out as i have school today and lighting was poor.
My question is: Is the front suspension setup similar to that of the S13? I ordered a new lower control arm and radius rod which should be waiting for me this afternoon, and ill try know it over tonight providing nothing else is broken. I only ordered these parts as i could see the control arm was bent and my mate did the same thing a month ago in his S13, is there a possibilty there are more suspension components that i am yet to see? And if neone has done a similar thing, are there any other things i should check or pay particular attention too??
Cheers
John
its not the same man, let me get this right u crashed in reverse ? damn dude, u should never do silly things in reverse, specially in the dark, thats like when a car is the most uncontrollable! tough luck man hope u find the parts. check everything man!
He went round the corner in the opposite direction to what he was originally doing it in.
Good one John.
I would replace all the suspension arms, personally, if it smashed a wheel. 1-2mm out = stuffed alignment.
Get it fixed for the 5th!
hahahaha cheers for the replys guys, not in reverse slip got it right. Yeah the suspension is similar to the silvia but the skylines look much better built and stronger (haha to a point!) cars back on the road it was a 2 hour job, only had the replace the control arm and the car drives exactly the same as it used too, its booked in for a wheel this morning alignment but i dont really think it needs it.
PVA_GLUE: Drift a WHALE!!!!??? NOT EVEN, we have some awesome footage!!!!
boostimports: I go to brisbane grammar
cheers for the replys, there's still the one months wait for a new mag, and i need a new side skirt, but i spose u get that.
I dont actually have the hardware, or software for that matter to put it on the computer yet, i was gonna buy it but then i had to fix the car, haha, ill do my best to get it asap.
boostimports: stereo type me! but seriously, i worked damn hard for my car, and im not ashamed to say my parents helped me out but i still worked damn hard for it, and so did most of my friends, but yes there are those few that are lucky and did nothing for there cars, A good mate of mine has a brand new M3, but no one gives him shit for it, he's just lucky to ahve parents that are prepared to provide him with shit like that.
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
