took mine out on sunday, cut my hand on various screws and stuff like 6 times.
In my r32, i unscrewed the fuel line bracket just forward of the filter, then got the filter to an easily accessible place, then pulled like a MF, just came off...
try getting pliers, clench just at the end of the nozzle ( on a soft spot in the line) and lever the pliers against the fuel filter... worth a shot... : )
i just changed my fuel filter on the last service its a bitch...
put hose clamps on either side of it so u don't spray fuel everywhere (also makes the car start much sooner after you have changed the filter) then remove the engine side first (pull damn hard (don't yank it from the engine, hold the hose and the filter and pull them appart) then pull really really hard to get it off from the fuel tank side. thats the hardest....*
My advice is to not do up the hose clamps too tightly when you put the new one in, because I reckon this is what makes the hoses harder to get off next time. Just tight enough to not come loose should be enough.
when i did mine i rememberd getting one end off but the other was tight asss....so i just cut it off...haha. im very paranoid so after i put everything back together i went over the hose again with a wet rag to neutralise any petrol that leaked in case it ate into the hose or caught on fire from the engine heat. as i said im paranoid...lol the car was so responsive after that. any idea on how often the filter should be changed??
Guest RedLineGTR
depends how u run your car also...if u run it to empty then alot of the shit in the tank is more likely to get sucked up...if u leave like 1/4 or abit more in the tank before u fill up, dont chnage it too often...but its a simple thing to do, makes sure your engine gets all the fuel it needs and wants.
No one has yet properly explained to me why this is the case. I don't buy into it personally.
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
