hey guys
just wondering what kinda power the standard rb26 injectors and airflow metres will handle im looking for 400rwhp i currently have hks gtss and a forged engine.
can i use rb25 afms if so what needs to be done to get them to work on the 26
and what cc injectors would i need?
cheers
stock injectors and afm ahould do around 280rwk before you come into too much trouble. I bought 540cc injectors for my car as i dont want a grenade setup :D
as for the afm's..., dont qoute me on this but i think the standard r32gtst afm's have the same plug as the rb26.
i read this somewhere a while ago. they are the same size as the gtr afms too, if this is the case they will do 400rwhp.
IIRC about 280awkw is the limit (someone will correct me). You can tune past the AFMs, and if you wanted to get a bit more out of the standard injectors you could raise the fuel pressure with an aftermarket regulator. Since you've spent the dough on the forged motor i wouldnt bother with the regulator hack and just go for a new set of injectors. To get changed AFMs and injectors to work you will need a tune. You might be able to get a PFC to limp to the shop if you select the new kit in the menus.
yep 287.4kw we made this at sau dyno day a few years back...de-screened afm's stock fuel pressure and injectors....stock turbo's etc
You should get close enough to 300.
Ferni has near on that power, stock AFM/Injectors.
If you want to push the turbos to the absolute limit, you'll need to upgrade both however
What is the injector duty and mixtures near 300? Stock fuel pressure?
If its running on the ragged edge then the OP could be well advised not to risk his shiny new motor. Ie stick to a safe 280, or add the goodies and run 320/330.
BTW Chicken at 200bar sounds delicious.
De - screened afm's. How much restriction do the screens pose? I have thought in pulling the rear screen off my nismo AFMS. Is it worth it? Would taking both screens off have any effect on how the AFM reads?
No need to descreen nismo afm's. They will meter just about anything you can give them. You can run stock motor, stock afm, stock fpr making 280kw atw with inj duty at 92 %. All in the tune.
AFM reads air mass so removing the screens will have no effect on the accuracy of the reading. The screens are just one of the many restrictions along the air path. I have no idea if removing them would make a measurable difference in power.
A mate who has WAY to much time on his hands worked it out (measured the size and length of the wire). The screens blocked 33% of the AFM he reckoned. Unfortunatley he never did a run with and without.
when but when air is being sucked past?
Huh? I
ts either the fact that ive just about finished a 12hr night shift or that makes no sense?
A screen both sides of the afm, restricting there air able to enter the afm. So you have an 80mm body with a 1/3 blocked by the screen.
god i need sleep.
6%
Huh? I
god i need sleep.
its not like the air is just 'passing'
its being sucked in, the turbos, spinning, draw more air
So under load/induction, how much does it actually restrict....
Paulie says 6%, is it more/less/otherwise?
I have a RB26, and having issues at the momment can I post it here since were here? Also to this topic. I got my injector maxed out to nearly a 100% at 12 psi on stock turbos. got 209kw@7500 rpm (280hp) at rear wheels. and that wasn't spinning that hard, is a new engine can go to 9500 rpm with more $$$$!
To this new topic about MAF's, I was thinking of pulling the mesh off my sensors to clean them better. Alot of oil been through them. I have seen a DIY fix for these meters where U have to re-solder the filaments to the probe (I wouldn't advise anyone to doing this though). They are a sealed unit, with the time you waste, might as well just buy a new or good second hand one.
It wouldn't be a good idea to remove this mesh with a standard ECU would it? The voltages under throttle and none throttle be affected. Maybe not.
you do not solder the "filaments to the probe" as you put it....the dry joints you solder are located under the square cover.
    • You can’t see much on the other side as the lcd is there I don’t think it’s the same as the m33 beside it as the markings on top is not the same was hoping someone had a good quality photo or if they just happened to have the unit in hand, quickly take the cover off and take a photo to clearly show the marking on top to identify the diode   the unit is currently with an electronics repair shop so I can’t take another photo at the moment hopefully they are smart enough to know if it’s a zener diode or not
    • I'd be very surprised if you can buy new OEM mats. But if you can, I want some too!  Do you have links to the variations you found? Also, where are you located? I found that Nengun is happy to list items to purchase but when you do buy them you'll get an email that it's actually discontinued. As far as I know the variations in floor mats are different colour schemes as well as automatic and manual having a slightly different shape. The automatic ones fit into a manual car without issues, but I think you'd have trouble fitting the other way around. I have photos that show the shape difference if you care. FWIW I bought sets of used floor mats in decent condition at yahoo auctions.
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
    • Hi, Marek here 🙋‍♂️. I finally fulfilled my longtime dream - recently bought Stagea and now waiting for it to arrive in Poland. There's only few of these in my country, and one of the owners  recommended mi this forum as a source of all the info i'd need since now i own one  so here i am.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
