  • Replies 58
CRD have a some sort of 'new' GT30 turbine cover. whether it is a VG/OP6 housing or some new casting isn't clear but worth keeping an eye out since they will be posting some details in the next week or so.
andrew @ CRD would be worth asking before committing to an externally gated turbo which will have a number of extra costs to get up and running. check the CRD trader adverts here.
  • 1 month later...
yes for sure
waiting upon 07 tax cheque return, then will order a GT2871r 450hp garrett-bb turbo from Hypergear, including lines etc, bolt-on.
will do the mirror rust fixup, and perhaps black pearl paint to the roof, bonnet and mirrors
then a rechip ecu map over a 4wd dyno from jeff at The SpeedLab, retuned for the better turbo & current set-up
Could this mean, Brendo, that you will own our first Panda-spec Stagea? i wonder what it would look like.
i have seen two with black bonnets on the roads, plus i think Fuzzy's old one was black bonnet too?
well had the stagea retuned today
pulling the 200kw mark now at 13.5psi
best tune by Boostworx tho, golden. feels fantastic on the road whether its on or off boost
Any reason why you're not running more boost (e.g. 16psi)?
on the road Ive upped it to 1bar
at around xxxkmph it starts tappering off boost on road, tappers down 1andabit psi to 13.5
got to cut the fmic lead pipes out of the fmic and redo a pipe, then should be ok - apparently
thanks mike. appreciated
ryan I agree
roof - I wouldnt do the white stripe on the outside of the rail racks, up the windscreen along & down back. but yeah, NO not good
bonnet - can I have a photo shop please of bonnet only in a shiney black ? if possible? please?
cheers
yeah, at this stage Um no, just rust fix and fixing body-touchups
sorry about the quality of the chops, doing them real quick when i'm meant to be doing my uni work
no no thanks very very much, havent really chopped photos b4.
sorry, wont ask again - get back to the studies !! and best of luck too.
cheers for the pic as requested, muchly appreciated :)
duno bout the black i think the bonnet would look betta in the flesh but still duno?
if you want me to price up doin the rust at work let me no. to get that colour rite we would have to blend through the guards so it couldnt be too cheap thats why i havnt got round to doin mine
will do - already got my paint in two tins and spec sheet etc, from Protec paints
yeah would love a price !
cheers mate
    • So I actually had the cover off my car today, here is a (bad) pic of the setup. I have an oil cooler thermostat block, the temp sender is straight in there. The pressure sender has a short AN line to a T piece which is mounted (hopefully cable tied counts as mounted....) on the chassis. BTW every fitting you could ever imagine exists....just depends what they cost and how many you need. Raceworx AN adapters are here: https://raceworks.com.au/fittings/adapters/, I think you said you need BSPT to AN (https://raceworks.com.au/fittings/adapters/bsp/tapered/an-to-bspt-adapters/) and AN to NPT (https://raceworks.com.au/fittings/adapters/npt/) BTW, braided line is super simple to make. It looks intimidating, is not.
    • Perfect day for a pie, really needs a soft top in this weather though
    • Prime parking, she is a little girl...LOL
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
