unless they have created one in the last 3 months, they do not do one.
Only for S1 & S2 Stags.
If you speak to Mike & they do, please let us know. There are a few guys on here that would be very interested.
Edited by iamhe77
https://www.sau.com.au/forums/topic/253072-m35-shift-kits/#findComment-4376063
I spoke to Mike in September last year and they said they can do it. They don't have a spare valve body so they can swap it on the spot like they can the C34. From memory he said about 2-3 days to do the work.
Cheers
Andy
https://www.sau.com.au/forums/topic/253072-m35-shift-kits/#findComment-4376067
Cheers
Andy
I stand (sit) corrected.
So I guess they are not couriering it out to people in other states then?
https://www.sau.com.au/forums/topic/253072-m35-shift-kits/#findComment-4376073
try knox autos in rowville, and also there is this thing called capslock, when the light is on its BAD
Knox Autos = 4 speed box only at present.
I spoke to them and had to explain what the car was, let alone get a price on a shift kit.
unless they can get hold of the MV kit, I suppose.
Edited by iamhe77
https://www.sau.com.au/forums/topic/253072-m35-shift-kits/#findComment-4376977
I was in adelaide over new years and was very tempted to get mine done.
Would be very interested in hearing from anyone who gets this done!!
And I will definitely be keeping it on the todo list - might not be this year though... :P
https://www.sau.com.au/forums/topic/253072-m35-shift-kits/#findComment-4379004
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
