Yeah mate same boat here, i have a power fc though and i think its something do do with fuel/ignition timing vs intake temps on startup?
never sure but last 2 days its been hot and my car has taken a couple of attempts to start.....same in very cold-start conditions.
:D ignition module or coil packs or something else???
any help appreciated
What ECU do you have?
Go into 'settings' then 'cranking' and have a look at the 50deg and 80 deg settings.
Change the 80deg to 9.0 and the 50deg to 10.0 and see if it starts easy for you.
oh mad, ill take a look at my controller and report back. Thanks man
Apexi power fc, nah mine wont start at all when its hot.
Bought an fitted a new ignition module wasn't that. it was a waste of $900
still have to push start it when its hot :D very embarrising in the middle of town.
ordered new set of splitfires should arrive tuesday
*oh sorry i meant when the engines hot not the air temp.
Edited by Country Cruzin
yeah i agree with stevel, sounds like its the starter motor, make sure your alternator is also working though and your battery is ok. should be 13.6ish-14.5ish volts when the car is running(at the battery). and if your battery is over 3 years old id almost consider it f'ed.
Im very confident its the starter motor. I had the same problem 2 years ago when i had a FORD PROBE. Same deal, wouldnt start on odd occasions. Changed the starter my self (easy to do) and the problemm was fixed. Give it a go i say
still have to push start it when its hot ;) very embarrising in the middle of town.
wont be coil packs either as others have said... push starts = starter motor.
my mate had this issue, check this thread out
http://www.nissansilvia.com/forums/index.p...=356831&hl=
"yea i had this issue on my rb it was voltage drop ( once the car gets hot the power to the starter is actually less cause the voltage has more resistance in the wire)"
:) No not the starter motor, motor turns over quite easily for the first six attempts than starts to slow down as the battery gets flatter. just wont fire up.
the reason i think it could be the coils is it runs fairly rough on idle after driving/thrashing it for a fair while, seems to miss a bit down low.
only started doing it since i had a lot of work done to it boost turned up to 20 psi ect. the mechanic said the coils mightn't keep handling it.
an that was his guess of the problem.
did you try changing the cranking values as dan said - I have had this exact problem you are describing put up with it for months till I called into ERD last weekend and he has the car hot starting in a matter of minutes...
I have the same problem starting mine when its hot. Not the starter motor as the engine turns over fine. If i don't get it started on the first attempt, it wont start at all....just keeps turning over...
However (don't ask me how i figured it out), if I disconnect the first injector and try again, she will start, then I plug in the injector power again :D:(
I reckon it is over fuelling or something because I can smell the fuel in the engine bay, and black smoke comes out of the exhaust after it starts.
Any other ideas?
BTW im running a NISTUNE remap. Would take it back to the tuners but some 'champ' rear ended me so I have been following that up....
Reason is Starter motor, I have it right now.
Unfortunately the starter is fairly expensive. Either the heat shield has been removed in perhaps a clutch install or the starter is shitted itself.
it will eventually die, until then it may start with abit more gas and longer ignition.
secondly its not the tune... at all.
douse sounds like a fueling issue with ur car.
to fix replace starter, install a heat shield. it stops working because the starter absorbs heat and it requires more power to fire. you may want to try run a bigger ground first, check the power at the starter first warm vrs cold. or perhaps warm car up let it sit for 20-30 mins when it absorbs most heat and then hook up a jump start see if it fires then this may mean the battery is rooted.
My 33 has a PFC. When it's really cold it cranks and starts but I have to keep revs up above 1000RPM for a few seconds with the throttle, otherwise it sort of bounces revs and stalls.
Is this a cure or any other ideas???
Cheers,
Ben
However (don't ask me how i figured it out), if I disconnect the first injector and try again, she will start, then I plug in the injector power again :D:P
Sounds like a faulty temp sender. The ECU thinks the engine is still cold, so it adds lots of fuel for a "cold start"
will this change the tune at all??
dont know much about tuning at all, just know it was dyno tuned for hours an was told that, down low on cruise he has kept it as lean as possible an at 20 psi its running rich but on its limit of knocking. an a slight change to the tune an the engine's buggered.
still waiting on new coils should arrive any day they've bn sent. other wise i'll have to plan a trip back to brissy an let mark figure it out.
    • Hi guys, long time no post as per usual! It's been a busy year so far, the biggest thing being a new job.  After 28 years in the automotive industry I decided it was time for a change.  I was losing faith in the industry and where it's heading.  Now in a completely different industry (electrical) working for a company that manufacture water pump contollers.  Not as sexy as cars but it's an interesting,  challenging industry. I now don't work Saturdays which is a bonus!  It's still 50-55 hours a week but having Saturdays ack after 28 years of working them is awesome!   No news on the GT-R but i did decide to add some more JDM goodness into my life....           1990 300 ZX.  She's not perfect but for a 35 year old car she ain't bad!  Just going to tidy it up a bit and enjoy it.  It's currently auto but will start stockpiling everything for a manual swap. It WILL distract me even further from the GT-R but im hoping not for too long! It somewhat proves a 6'8" freak can fit in a 300 ZX.  Sort of...  I drove it home from the previous owners house in Melbourne via Black Spur and Merton Gap (2 awesome bits of Victorian twisty road) and it was amazing!  Handles so well!!!   I don't think it would be worthy of a full build page but I'll post up some of the upgrades here if anyone is interested?  Cheers guys!
    • End game is to: - Remove all the slop from old worn parts - Adjust setup so that the wheels actually fit and the car is drivable (currently it is not because of the extreme rubbing on the guards).   Progress over the last couple of days, removed the rear hubs! Next steps: - Buy bushings - Replace bushings/bearings on hub - Reinstall
    • Cracked deck  And other cam snap stuff
    • A few random issues have popped up since my last update. My WMI pressure sensor failed within about 10 minutes of it seeing liquid. It was a 20$ China special, so I'm not surprised. My name brand replacement should arrive today.  My power steering assist also decided to crap out last weekend. The usual, works for about 60 seconds after starting the car then I lose it. I dusted off my old copy of NDS and connected to the HICAS ECU. Code 4 for assist solenoid.... I tested the solenoid and it's fine.  I knew the day where my HICAS ecu would crap out would come, and I welcome it. It was the last HICAS part on the car that is now in the bin. I've ordered an SSR and I will control the power steering solenoid with my Haltech ecu. It will be nice to have proper speed referenced assist again after all these years.
