Have you washed the engine bay with fairly high, hose, pressure. If water can get in anywhere this could cause the prob.
Also have you discon the battery pumped the brakes a few times to reset the ecu?
no cleaning of the engine with a hose at all....
is that all u have to do to reset the ecu?
It was an engine fuse, Hugh. We got that sorted out and now the battery light is on. Hopefully that's just another fuse issue or at the worst just the regulator on the alternator...
check your fuse for the horn isn't blown
i actually had the fuse for my horn out, i had to use it for the engine one that had blown until i could get a new one....i replaced it last
night at the same time as i gave the terminals a good clean so i cant say 100% which act it was, unless u can tell me the horn fuse being
out would cause the battery light to come on?? why on earth would that be??
It would run in series with the alternator cct.......a very weird way of doing it but that is just the way it is.
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
