I just ended up going with Just car...
premium of 1550 a year thats i think at $152.65 a month
Heres the bitch part lol...
Excess 2550...
at an agreed value of 13500. What you guys think of all this.. I have a series 1 r33 1993 running 220rwkw but should be more now since the turbo's been high flowed.
Sid
I just changed from Just car to SGIC - they certainly insure R34's, they did say that they only insure turbo's on over 25's.
300 bucks saving and benefits like windscreens, hire cars etc...
Last time I checked with them a year ago they wouldnt do it. So worth giving them a call imo.
yeah good call and when you say to that market you have to be 25+ that cuts out a whole heap more
EDIt
i just tried the SGIC online thing they will insure me but there standard cover was like $3900 and i could up it too $6900
would have to ring them i think
sgic dont insure skylines, unless they have changed their rules but i doubt it
When I moved out of home I swaped to my girlfriends insurence SGIC, from Wesfarmers because it was easier for her.
-I had my S13 drift car insured for being in the garage, workshop, trailer.
-R33 with the forged RB26.
-Now my 180 with them.
Also got discounted because my home and contents is with them. Had no dramas at all getting insurence either :D
Oh and I'm also 22 (23 soon :s ).
I just got a quote from SGIC...
22 years old, no accidents
1989 R32 GTR
Agreed Value of $30,770
$1460.43 basic excess($800) or $1217.02 if I increase the excess($2000)
God damn, think I'll be changing to SGIC after my insurance runs out in March or whatever it was or bargain with them to give me a better deal!
haha Yeah that would make more sense :P
But pretty much ever time I get insurence I'm insuring more then my car which most companies wont pass up haha
Also upgrading my private health. That cost more then my car, home and contents cost together!
Edited by Import S13
mine was something like $56 monthly buy cover up to 3.6k extendable to 6.9 or something
Edit
just did the quote thing again
$ 488. 48 annually
or $45.62 monthly $3900 cover
just cars for me was only $800ish for 16-17k cover
OR
$ 573. 12 annually
or $53.25 monthly $6630 cover :blink:
Yeah fark, SGIC for the dirty whore is:
$1197.10 annually ($108/92 monthly)
the big downside is they will only cover up to 15g, i have to ring them to get market value.
Is 15k the max it would allow on the web quote? Geez what value was on the lowest end? lol
Steve, tell me that quote was for the daily hahaha
for a 1994 skyline sedan a coupe might have different results
EDIT
yeah flaming mongrels
i just did it as a coupe and got very very different reslts and thats all i changed was body type
$658. 85 annually
or $60.98 monthly $14500 value
844. 72 annually
or $77.74 monthly with maximum value added of $24650
    • Hi guys, Making some space/cleaning up. A whole heap of random OEM R33 GTR parts and other random bits and bobs. I will update this thread as I go. Parts are located in Moorebank NSW 2170. Pickup preferred but will post at buyers expense. Prices are negotiable. If they don’t sell it will go in the bin. Item 1: BOV return pipe. $40 Item 2: RB26 cam gears. $20 Item 3: R33 GTR torque split, oil temp, boost centre gauge. $100 Item 4: RB26 fuel rail x 2. $20 each Item 5: RB26 Recirc valves. $50 Item 6: OEM upper front arms. $20 Item 7: Royal Purple Max Gear 75w-140 1 quart/946 ml x 5. $50 each or 5 for $200. Item 8: OS Giken 80w-250 diff oil 1 litre. $25 Item 9 Eibach springs. ers-11-140-60-0140. $100 https://www.streetfx.com.au/eib140-60-0060-eibach-ers-140mm-length-x-60mm-id-coil-over-spring?_ga_campaignid=22235933977&_ga_adgroupid=180146800292&_ga_keyword=&_ga_device=m&_ga_target=pla-295238231169&_ga_locint=&_ga_locphy=9071723&_ga_matchtype=&_ga_network=g&_ga_device=m&_ga_placement=&_gcl_id=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE&gad_source=1&gad_campaignid=22235933977&gbraid=0AAAAADPiTbo1xAuvnjIWWYnezivf-BUSY&gclid=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE
    • That's kind of what I was getting at saying you'd be here soon regarding length etc being able to add additional restriction.  My assumption (possible donkeys of you and mption) is that the length of hose to an oil cooler, and back, isn't going to be that huge of a loss. Typically you're talking about 1.5m of total length. And so far everyone in our world hasn't had issues with oil not being able to get to a cooler and back, it's more been, how the heck do we get the oil out of the head and back down to the bottom? I'd nearly hazard a guess the biggest issue people have with oil cooling and oil supply, is being able to get the heat out at the cooler itself (not enough air flow, too small of a cooler etc) Also, when people mount them wrong and make really awesome air traps so they've dramatically diminished the cooling capacity.
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
    • To pick up what Dose is putting down. Not a lot of point running a huge hose if the motor is still restricted to the smaller size... It's only capable of flowing so much at that point...   *Waits for GTSBoy to come in and bring in the technicalities of length of pipe, and additional restriction from wall friction etc etc*
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
