  • Replies 219
Posted Images
what time do use think the cruise will end??
and use need to get sum promo models ;)
xx
y dont u come in a bikini ur hot enough to pass come say hello to me and stealthed and niskmo we all be there names scott by the way
hey guys and girls was a good cruise sorry i could not stay long missus was not feeling good the fumes where making her sick cos she is pregnant but will be sure to be on the next one will have my P's back to oh and by the way i was the guy in the Black Liberty with the L Plates on it lol
Patick
bailed after hillaries, map needed more 2 lane roads.. stuck in traffic and traveling at 10kph ftl
yeh stuck in traffic ftl -.-
too many cars that time of day too. would have been quite a few nice roads if they were empty.
Edited by Soul
was fun bailed after i got pulled over for small tire screech when turning at joondalup [yes im that idiot] =[ my friend shoved the map in her pants...
Edited by R34P3R
what a wikid day drifts then cruise and cause i rode shotgun i got pissed yippe all fun till cops at joondalup what a bunch of C*%ts that was straight out abuse but oh well what can we do cop the yellow aaron call me about working on ur car to get it off was awesome night hope we all had fun
Guys, thankyou all for coming out. I was so stressed with shit maps, cops, ect but it all worked out. I have no idea wtf happened at Joolndalup but I'm glad you all went to Malaga straight awayvanf kept cruising. I'm gonna find Penguin St tomorrow as well...
A HUGE appology for the map, I know it's my first time but there was still too many mistakes for my liking. Thanks fir stick with me. There us another cruise in the pipeline, and I promise it'll be 100% better. Any constructive critism is welcome. I'm ok with it, I was expecting to be flamed on here so thanks for everything.
Bubba, you forgot to introduce yourself. Your the guy with the beard in the Stag, yeh?
Thanks for everyone who cane said hello. Problem is I didn't know you :D So next time introduce yourselfes! (Looking at you Pat and Chris)
Andrew, thanks for the help at City West. I didn't realise you were waiting there before getting Luce, I appreciate it.
Mel... Good luck with your lil " mission" (you know what I mean :banana:)
I'll catch you guys next time!
Very Nice Cruise Rhys, Even though a couple of mistakes It was still a Good Run :(, Dont know why we were going to Truckstop but, coulda Saved some Fuel haha
Interesting Night :banana:
Heres Some Photos Ladies' -
Heading to CityWest,
Sure It was Sauce Nick.... :D
Cruise -
And Once again......This One's For Scott :D
Only Video we got :banana:
http://www.youtube.com/watch?v=nFyHalNCnRQ...re=channel_page
:( naaaw thanks!
i missed out on this cruise ):
sounds like it was pretty good tho,
two of my friends went (:
in a r33
2 brunettes
ne wun spot them??
ehehhe
need more pikies
lol
:( naaaw thanks!
in a r33
2 brunettes
ne wun spot them??
ehehhe
need more pikies
lol
That would be muzza good guy and ya sorry for not introducing myself the missus was not feeling the best and was pissed with me for dragging her out on the cruise was her first one she enjoyed alot so will be seeing alot more of me lol.
Patrick
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
