I run -7's with a shitty exhaust and stock afm's. With id1000's and a walbro 400 fuel pump I make 325kw on 20psi with E85. If I fix my exhaust and chuck some bigger afm's on I'd probably crack 350kw.
It'd be much easier to do it with -9's and I don't think there would be much more lag involved.
What exhaust you going for?
Ok, had a play.
Your car is obviously tuned in 3rd gear going by the speeds. It's a bit rough but you get the idea.
3950: N= 176 P= 215
4400: N= 252 P = 300
4800: N= 306 P = 375
5244: N = 326 P = 415
5644: N = 344 P = 445
6100: N= 350 P= 460
6500: N = 342 P = 472
Take into consideration how they were loaded up for the runs and whatnot.
Just out of curiosity...
I have a set of -5s on my std RB26DETT and i'm only making 300kw on 22psi...
The things I noticed are my actuators are set at 8psi and I have 600cc injectors coupled with a Walbro 255 pump.
Are these going to be an issue or is it a tuning issue?
EDIT- Using 5speed from RB25 and 4.08 S14 Diff in an S15
Edited by TheGeniusMoose
Thats what im trying to figure out! My injectors hit 100% duty cycle on full boost thats why I thought my pump or injectors were maxing out but doesnt make sence I should be making 300kw on less than 20psi id have thought...
Previously I had valve float but that has been rectified.
Nothing at the moment as I'm content with the power. I think I'll get more gains if I upgrade my actuators 1st and see how I go.
Eventually I'll rip the cat out and the 3" exhaust and replace it all with 3.5".
Ok, had a play.
3950: N= 176 P= 215
6100: N= 350 P= 460
Was 4th gear he doesn't tune in 3rd
Well the 255L was an upgrade on the SR lol. What should I be aiming for when I buy a new one?
The pump provided its getting the right voltage should have an issue with that power. I think it's time to put your inspector gadget hat on and start investigating.
I'd say, once again, attention to detail on the setup is where the better results are. Big, size matched exhausts blah blah.
Got a sheet Nick?
Exactly.
I had 340rwkw with -9s on 98, but it wasn't a stock engine - and that is where the extra bits/gains come from
I see!
An actuator upgrade will do it good.
Yeah, if you want to get over the 350 rwkW mark, go 3.5".
Exactly.
+1
Other thing is the turbos are REALLY laggy.
I get 18psi by 6000rpm and power drops off completely at 22psi at 7500rpm so theres no point revving past there...
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
