  • Replies 138
yeah i read all that cheers, signed up to the ford forums now so having a read thro it all.
whats the diff between the BA-BF deka's and the FG deka's? and which one do i need for the neo.
cheers
i have no idea about FG falcons................ seimens injectors are used as an upgrede not stock. ie Siemens have branded this injector DEKA. if you find any thing has changed let me know.
Well, thanks to urtwhistle for his hospitality yesterday, it seems all I have to do to fit my RB20 injectors (same would go for GTR injectors I guess), is machine the bosses down a bit on the manifold where the fuel rail bolts and change the manifold side o-rings on the injectors.
Actually.. just had a thought.. Chris, what length are those spacers you are using? I only checked against your seimens injectors and forgot you were spacing the rail.. if that's the case then I'll probably just need a smaller spacer (couple of washers) instead of machining the bosses on the manifold down..
yeah i got that much cheers. So you ran the BA-BF replacement deka's then im guessing? as theres two diff part numbers (and prices) for the BA-BF and FG series.
Sorry mate if i came across a little abrupt, i was just feeling a little frustrated at the time. (was agro cos i lost a 10mm socket for a few hours)
oh i see i never realised there could have been a difference. Yes i went BA turbo injectors. siemens/VDO p/n FI114961
No problems, your welcome to drop past any time. its good being able to put a face to the name. I'm currently using a 12mm spacer.
you may be able to use some gr10.9 washers as they tend to be a fair bit thicker then engineering washers. give me a yell if you run into any trouble. i may have some in the bolt rack at work.
regards
Chris
if anybody wants a cheap set of the 80Lb (875cc) Dekas, ive got some for sale here (new).
http://www.skylinesaustralia.com/forums/wa...87#entry4806887
Ok i'm interested in these injecters.
I have read the whole thread but most of it relates to the rb25 fuel rail.
Now what do I have to do to make these fit? 23MM spacer with a longer bolt and longer fuel hose? Just so the fuel rail sits abit higher up?
hey fella, i have no idea about RB26's but yes i stated [b]13MM[/b] I ended up grinding them back to about 11MM as there was a bit of extra play there that i didnt like.
and being a GTR you probly dont need to worry about the fuel hose. But thats somehting you might need to look into.
So the fuel rail just has to sit higher? Thats it? The injecters that I looked at are top feed as well.
exactly and change the injector plugs to suit. but due to it sitting higher you either have to mod the rail so you can actually get the rail on the injectors.
or take the top half of the plenum off install the injectors and rail un modified. as the rail only clashs when your posittioning the rail over the injectors.
What cc are stock Z33 injectors? Are they a great bolt on upgrade for the ER34?
To my knowledge there the same style but unsure of the stock CC. i highly doubt that they would put bigger injectors in a NA car though.
regards
Chris
  • 5 months later...
Hey guys,
Was just searching on this for a friedn and realised that I know a guy who was getting the injectors at a great price. The LS1 and XR6T use the same style injectors, so the LS1 style bolt in replacement Motron 60Lb injectors would also work right?
If so, these guys do eight (yes 8) Motron 60Lb injectors for US$379 so surely US$48 per injector + freight and then buying injector clips etc would make them affordable compared to the Siemens Deka ones?
Anyway, the link is HERE
Edited by GTiR Racer
  • 1 month later...
siemens ones. not a whole heap of work really, needed to wire in new plugs and machine up some 12mm spacers to space the rail up. other then that its a bolt in swap.
oh and check out the tutorial section... i made a guide for it also.
Edited by Simon-R32
  • 1 year later...
so for e85 it currently boils down to);
nismo 740cc, can't find any.
deatschwerks $640 pp which is plug and play.
80LB SIEMENS DEKA INJECTORS for around $365 pp plus wiring harness and machining a 13mm spacer.
or ID1000's for $700 but some (lots?) mucking around to install
I had actually toyed with the idea of putting the R33 inlet runners on the Neo head and just using R33 side feeds on the stock rail....but I never got around to confirming the stud patterns matched up, anyone care to check it out?
I know this is an old post but I can confirm this works. I have an R34 neo motor with R33 intake, rail etc on it. You have to pull a stud out of each end of the head and replace it with the standard R33 bolt but it isn't exactly hard to do.
I did it as it meant doing the neo swap was completely painless, running all R32 gear (in an R32) sensors, ecu etc. Just chopped the ignitor off and wired the ecu direct to the R34 coils.
Easy as piss.
Edited by Rolls
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
