  • Replies 103
when an unoppend can of sprite in the back off your gf's car goes **!KAPHUKING BOOM!** right while you are driving in 43 degrees and now are covered in sticky sprite and ears are ringing...
I couldnt pick up what was left of the can it was that hot...
When you are calling the closest BUnnings to buy a generator and they are all sold out! Every single one of them! I called 3 bunnings to buy one and they were all gone. Had to go to Coburg from Melton!
Now have backup power for fridge and fish tanks of power goes out again!
yeah, but its the western suburbs
:P
My power is yet to go out...
The same can't be said for the whole of Crown last night however...Wouldn't want to see the amount of money lost by the Casino alone, not to mention every restaurant and store in there, as well as every Crown car park...
heres what it looks like at my place
purple is inside, light blue outside
the light blue is slightly higher as the sensor is near bricks (ish)
you turn you aircon off around midnight ey? hehe :P
Same with fans, all out. As was Kmart. Ended up buying one of the last desk fans left in target.
really?
my mums work lost power at around 4:30/5pm yesterday
and it's like 2 minutes from your house
must be on a different grid or something
when you tight ass Indian parents come to you and say
*in an Indian tone*
"son installing the AC in the house was a brilliant idea, fantastic"
hahahahaha
i almost fell of the chair when my mum came up to me and said that
really?
Went out for a bit last night apparently, but I didn't know as I was waiting outside crown to get a steak. Ended up at highpoint porchetta instead after standing outside crown for an hour.
My mate who lives just around the corner from me lost power at his house the other day but mine was fine
+1 LOL!!!!!!
when connex offers free public transport on a day that they know is going to be hotter and expect nothing to go wrong. seriously, do these muppets have half a brain combined at all?
http://www.connexmelbourne.com.au/news.php?newsid=482
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
