Hey Ash how do the -5's compare to the Trust T517Z 8cms? I know ball bearing is the way to go but wondering if the difference is worth the cash outlay? The -5's would probably come on earlier and make more power hey?
Yep, have had both, and the -5's were more responsive, a lot more....
517's made good peak power though.
Congrats on the buy, you got yourself a very clean and nicely modded GT-R...
Speak to Ben, he will tell you if it's worth changing turbos or not....
  • Replies 60
Thanks Jack, yep very happy with it :)
I won't be changing anything for the time being, its not like the car is super laggy, it still has a pretty brutal 4,000rpm powerband... just food for thought... the little surge of torque that ball bearing turbos have as they're coming on boost is nice
*SIGH*
Will you please stop posting up rubbish and factually incorrect information?
500hp is near enough to 300rwkw. 300rwkw is doable. You have that power yourself - go look @ your own dyno sheet.
Next time... Read the posts clearly and ensure you understand before posting.
It clearly says HP. Not rwhp.
/*SIGH*
Sorry maybe i should have stated 250 awkw
and that aim is for power at wheels not motor, i indeed did just put hp which i understand is not specific.
Thanks for all feedback,
I Think most people would lean towards -5's but of course everyone has different preferences
much appreciated feedback from a question most of you would have answered many times.
250awkw is in the realm of stock turbo's dude, if you get the -9s you wont be disappointed.
You wont be near the limits of them if thats all you are after. -5s are if you are looking for 350rwkw-400rwkw or there abouts.
Remember GTR's are 50/50 fulltime 4WD, the loss isn't the same
if it helps, mine with GTSS's yesterday evening did a 12.3 @ 110mph, with only 15psi boost, and 18 inch re-01's and a 1.805 60'. Oh and the track temp was 38 degrees and into a 13 knot head wind too.
A little more boost, a better launch (ie a 1.6ish 60') and 17 inch tyres should see well into the 11's!
Edited by R33GTRKid
Guess my 19's are slowing me down a fair bit then,
I Curently run a safe 1bar which is 14psi??
would it be unsafe to raise to 18?? until i install new turbos, don't want to damage my engine for tiny power increase.
110mph would indicate you only have about 220rwkw, 230rwkw at the absolute most.
With over 1bar, that does not sound right at all. It should be closer to 115-116mph
I was running 110-111mph with 215-220rwkw for about 6 months and over 50 passes.
Ash, you seem to live in fairy land:
http://www.tunercalcs.com/
My car stock dry is 1530, add 50kilos (full tank) add 110 fat bastard in driver seat = 1690 kilograms (3718 pounds), plus 380 horsepower @ wheels gives a rough 12.459, which almost spot on to my 12.346 odd, maybe I overestimated my fuel weight, or lighter parts from stock or whatever.
If you then select the estimated horsepower from trap speed http://www.tunercalcs.com/hp-from-quarter-...trap-speed.html and put in 3718 pounds and 110 MPH you get 386 hp or 288rwkw, Xspeed says I have 380 rwhp
If you were getting 110 mph with 220 rwkw, your car's gross weight must of weighed 2850 pounds or about 1300 kilograms which is pretty light
Edited by R33GTRKid
110mph and ur dreaming of 11's...
to be realisitic in a gtr without drag radials ur looking at least at 117mph
My car comes in at 1400 without me in it, so nearly 1500 heavy and 200kg's more than your website assisted guess.
I don't live in fairly land, you are. Your going off some website. I used to hit the 1/4mile once a week for about 4 months, you know, real life.
There is no way you have 280rwkw with a trap of 110km/h unless you are backing off before the end or whatever else.
I'll revise my estimate to say, 250rwkw, just to give you the benefit of the doubt ok?.
But as you'll see... not near 280, no way.
Example #1 - 12.62 @ 109.3mph - lucky to have 240rwkw @ 12psi, stock turbos (R33 GTR)
http://www.skylinesaustralia.com/forums/in...t&p=4175753
Example #2 - 12.4 @ 112mph - 315rwHP (admittedly thats a R32 GTR, but the weight isn't significant enough to get too excited)
http://www.skylinesaustralia.com/forums/in...t&p=2165896
Example #3 - ET:12.254 MPH:114.53.
248rwkw at 1bar (admittedly another R32 GTR, but its not THAT much weight to eat up 30-40rwkw when the MPH is higher to boot.)
http://www.skylinesaustralia.com/forums/in...t&p=2081953
Proof is in the pudding, or should i say... on the 1/4 mile
Dyno1.pdf
whatever, there is the proof of power
timeslip___5.2.09.pdf
there is timeslip, no did not back off anywhere.
Also interesting to note that F6 ute with 300rwkw doing 12.6's, another member with 290rwkw in his R32 GTR was getting 12.5's at 107MPH, a R34 GTR (the blue one from overeast bought from the dude off the forum) is next to me on the time slip and was getting consisten 110ish MPH the whole time and he reportedly has 450rwhp??? he was not backing off either.....
And I checked 4 different website calculators and they all pretty much came back with 110MPH being spot on for a 1690 car and 380 rwhp but of course you must be right :)
Could be that motorplex is just shite track, was heading into a 13 knot head wind, and track was 38 degrees but all I can say is what happened and what my car has.
Edited by R33GTRKid
MPH backs up dyno results, not the other way around.
So (in case you dont get what im saying) dyno sheet = doesnt mean a thing as MPH never lies.
You've run the MPH and its told the real truth. Easy as that really.
The plex is one of the best facilities in the country, ive been there.
So its not the tracks problem
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
    • Hi, is the HKS  Tower Bar still available ? negotiable ? 🤔
    • From there, it is really just test and assemble. Plug the adapter cables from the unit into the back of the screen, then the other side to the car harness. Don't forget all the other plugs too! Run the cables behind the unit and screw it back into place (4 screws) and you should now have 3 cables to run from the top screen to the android unit. I ran them along the DS of the other AV units in the gap between their backets and the console, and used some corrugated tubing on the sharp edges of the bracket so the wires were safe. Plug the centre console and lower screen in temporarily and turn the car to ACC, the AV should fire up as normal. Hold the back button for 3 sec and Android should appear on the top screen. You need to set the input to Aux for audio (more on that later). I put the unit under the AC duct in the centre console, with the wifi antenna on top of the AC duct near the shifter, the bluetooth antenna on the AC duct under the centre console The GPS unit on top of the DS to AC duct; they all seem to work OK there are are out of the way. Neat cable routing is a pain. For the drive recorder I mounted it near the rear view mirror and run the cable in the headlining, across the a pillar and then down the inside of the a pillar seal to the DS lower dash. From there it goes across and to one USB input for the unit. The second USB input is attached to the ECUtec OBD dongle and the 3rd goes to the USB bulkhead connected I added in the centre console. This is how the centre console looks "tidied" up Note I didn't install the provided speaker, didn't use the 2.5mm IPod in line or the piggyback loom for the Ipod or change any DIP switches; they seem to only be required if you need to use the Ipod input rather than the AUX input. That's it, install done, I'll follow up with a separate post on how the unit works, but in summary it retains all factory functions and inputs (so I still use my phone to the car for calls), reverse still works like factory etc.
