i got afc analog one with the knob would that affect anything and i never noticed it before as it never ever did it i notice it in the passenger side mirror are you guys sure this is safe.
also really dumb question how do you guys put those movies and pics under your user name
https://www.sau.com.au/forums/topic/25545-some-smoke/#findComment-543066
The one knob AFCs are essentially useless. I'd say I'm almost 99% sure that's what is making you run rich and causing the smoke. They only allow you to add/remove fuel across the entire rev range, so you cannot fine tune it. So if you are adding 5% fuel at 5000rpm (just as an example), you are also adding that at 1000rpm. Not efficient at all. To be honest, I have no idea why Apexi made it.
https://www.sau.com.au/forums/topic/25545-some-smoke/#findComment-543528
I got greyish smoke too :P
A couple months ago the engine made tapping noise which sounds very very similar to my old Mitsubishi Galant with valve stem seal problem :( unlike my old Mitsu where noise is still there all the way, in my skyline the noise is gone when engine is warm
But after detonation problem on a recent cruise, the cold start tapping noise is gone and hasn't come back since.... wtf????
Must be something else...
turbo seal on its way out?
is that tapping noise = turbo wheel touching its housing?
that detonation (due to over boost to 15psi) could have chipped the wheel edges so it no longer touch the housing?
I'm sure exhaust wheel still there, car can still make that much boost over 10psi (but I've turned it down to 8psi since)
https://www.sau.com.au/forums/topic/25545-some-smoke/#findComment-543543
Originally posted by rs73
I got greyish smoke too :(
A couple months ago the engine made tapping noise which sounds very very similar to my old Mitsubishi Galant with valve stem seal problem :D unlike my old Mitsu where noise is still there all the way, in my skyline the noise is gone when engine is warm
If the turbo wheel was touching the housing it would whale/howl not tap.
I would actually see a mechanic and do a compression test, amounst other checks.
https://www.sau.com.au/forums/topic/25545-some-smoke/#findComment-544637
hehehehe , try this go downhill a very long and steep hill stay in 4th or third gear do not touch the accelerator untill u get to the bottom when u get to the bottom of the hill eccelerate look in the mirror for smoke if u see blue smoke its u r valve stem seals . if it blows blue smoke under hard ecceleration and or high revs then its piston rings . just black smoke running a little rich but u'll get more at high rpm if running rich .
https://www.sau.com.au/forums/topic/25545-some-smoke/#findComment-544711
Al,
My turbo squeal like a mad pig on cold.... is that normal?
When warm it doesn't....
Anyway my car is now in the "hospital" now... hopefully
nothing serious...
https://www.sau.com.au/forums/topic/25545-some-smoke/#findComment-545055
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
