Welcome to the forums
Deca - http://www.skylinesaustralia.com/forums/Mi...ot-t255432.html
SAU Vic Renewal/sign up dyno day - http://www.skylinesaustralia.com/forums/Sa...no-t255356.html
If you sign up before the 8th, you could come on what is going to be an awesome members only cruise :D
There's a link to the online signup form in my signature below ;)
https://www.sau.com.au/forums/topic/255502-hey/#findComment-4406827
If you sign up before the 8th, you could come on what is going to be an awesome members only cruise ;)
There's a link to the online signup form in my signature below :)
Thanks Dezz
what time is the cruise on the 8th, as I got work and don't know if i will be able to make it.
also if i come to the sign up day with a filled out CAMS License form, will that be processed in time for the 1st DECA
Cheers :D
https://www.sau.com.au/forums/topic/255502-hey/#findComment-4406911
Thanks Dezz
Cheers :D
The cruise on the 8th is a members only cruise, so can't really give away any details...it begins in the morning and will run all day though..
As for DECA/CAMS, you can hand in your completed CAMS form along with the correct money on the day at DECA, and you'll be fine to compete. However you'll need to be a member of the club (or another CAMS affiliated club) to obtain a CAMS license. Otherwise you can get the AASA license instead.
https://www.sau.com.au/forums/topic/255502-hey/#findComment-4406951
Thanks everyone
I guess I won't be able to make it to the cruise on 8th anyway as i work from morning to after midday, so I'll try and attend the sign up day on the 21st and sign up there, hopefully it will still be running at 3pm as i finish work just after 2pm.
Might try to get out early to make sure I make it. :)
https://www.sau.com.au/forums/topic/255502-hey/#findComment-4407098
Thanks everyone
Welcome mate..
Hope to see you at the Dyno day..
https://www.sau.com.au/forums/topic/255502-hey/#findComment-4409310
Thanks for the welcomes everyone, I will hopefully see you all down at the dyno day
Hey man welcome
nice car!.. you wouldn't happen to have been parked all day on stanley st in west melbourne today?
Nah that wasn't me, I saw what looked to be an identical 180sx to mine in tha dandenongs though
Welcome aboard.
im planing on being at the dyno day myself, hopefully will see you there...
nice car by the way, i very nearly bought a 180sx myself once. ;)
Hopefuly see you at the dyno day.
What stopped you from getting the 180?
Can we Originise your 180SX?
:happy:
I would love to Originise my car, but right now I am a little short on money as most of what i saved went towards buying the car itself
How much is this kit anyway?
https://www.sau.com.au/forums/topic/255502-hey/#findComment-4410103
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
