  • Replies 82
Posted Images
Seems to look like Paul Walker will once again have his hands on a blue R34 GTR in the latest of the fast and the furious movies (Fast and Furious). In 2 Fast 2 Furious he was driving a blue R34 GTR for about 1 minute. Can we see this car as the main feature of this highly fictional (yet not bad viewing) movie?
also vin diesel doesn't look as staunch as he does on his other movies
here are 3 trailers to it, budget is definately bigger, looks decent...ish.....
http://www.apple.com/trailers/universal/fastandfurious/
Saw an R35 GTR on set, dunno if it'll b featured in the movie but someone making the movies got one otherwise
The 2F2F had the R34 GTR with the FWD disconnected, it actually had a (claimed) 13second quarter mile time due to this, they have the car on display at there studios in LA.
Not surprised that the new one also has the front wheel drive disconnected
Yeah I read about that.
What a terrible 1/4mile time... A stock R34 GTR runs 13.7secs best it can run is 12.9secs (Approx).
The 2F2F R34 GTR was equiped with all the performance parts and probley had the NOS system hooked up, surely can do better than 13secs.
Got no idea why it was RWD and they were not drifting it either...
4WD launch FTW!
Oh Oh !! me next.
Last time i recall other people in the cinemas, naming cars, naming engines, etc etc, just going on and on non stop throughout the movie... pretty much yelling it out, but pretending it is only to there friend.
Quite funny, some have a slight idea, most are way off.
i like the part in tokyo drift where they are on the freeway in the Rx7 and you see a glimpse of a blue 34 GTR go flying past them... then he fires a NOS shot and rips past the r34.. and the cops :blink:
Who cares about sales, my car just got extra bonus happy cool points!!!
:blink:
Never go FULL retard
hahahah
i was at the coles car park behind chapel st a few fri nights ago, wanting to park off chapel to escape the dero's, and dear jeebus, it was mini FnF set.... soooo sad
i like the part in tokyo drift where they are on the freeway in the Rx7 and you see a glimpse of a blue 34 GTR go flying past them... then he fires a NOS shot and rips past the r34.. and the cops :D
Yeah and that bit where you can see the UFO following them in the sky and then it turns on it's neons and gains another 12,000hp and rips past the airliner.
And that part where all the racers pile into that yellow bus to go back to the centre, thats way cool. :banana:
I think most of them are actually GT or GTTs - Look at the general stance and the wheel arches and don't GTRs usually have a red rear fog light???? Even then - what a waste of R34s ;)
yes YOUR RIGHT!
you can tell they are GT-Ts
no wonder they dont look quite right.................................then you realise the rear guards arent even flared.......looks like dogs balls to me....................
waste of GT-R badge..............if you ask me........
when i watched the extra vids on the 2nd movie they said they usually only have 1 real car that is the master car and doesn't get a scratch on it. that one is real, but then they have 3 or 4 others that are basic inside, but made to look exactly the same, which are used for stunts and things like that, so they get knocked around a lot. you'll probably find that the gt/gtts will be only in stunts in the movie so you wont be able to tell they arent real gtrs
watch for the rear quater pannel guys!!!!!!!!!
and if you spot them....post them onto MOVIEmistakes.com!!!
lol
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
