  • Replies 47
Posted Images
Could be anything really.
I would assume the red light is for your alarm when you arm it it blinks to tell you its on...
The siliver flick switch, Im guessing a RWD/AWD or 4WD switch..? Could be some activation switch for flog lights...
Can you pull down the compartment lid that its stored in and trace the wires and connections..?
https://www.sau.com.au/forums/topic/255712-mystery-switch/#findComment-4409863
try it and see?
maybe it's a simpsons style switch for 'MERRY CHRISTMAS 1984' on your roof?
Lol I tried it and it doesn't actually seem to do much when the car is stationary. Not really game enough to fiddle with it during driving, in case it kills power or locks the steering or something bizarre.
https://www.sau.com.au/forums/topic/255712-mystery-switch/#findComment-4409864
Lol flog lights. The compartment lid is for the moneybox... can't see wires in it. I checked and you're right about the red light.
It would be awesome if I had a 2WD/AWD switch there without knowing it.... Wax On, Wax Off, Drift On, Drift Off.
https://www.sau.com.au/forums/topic/255712-mystery-switch/#findComment-4409875
Doh! FOG lights I mean. LOL!
Maybe switch on the car and let it idle, then flick the silver switch and see if any lights pop up in the dash / cluster were your speedo and tachos are... Also hear out for any noises when the swtich is flicked...
Or take it hard around a corner then pull over, let it idle for a minute or 2, then flick the switch and take it hard around the same corner to see if it makes any difference...
My friend Tim GTR on SAU has a R33 GTR with a flick swtich and its for the 2WD/AWD switch and when you activate it, there is a a quick "Humming" or a very low tone "Beep" "Beep" noise.
But thats just his car.
https://www.sau.com.au/forums/topic/255712-mystery-switch/#findComment-4409905
No sounds or icons light up when idling and flicking back on forth with the switch. I might try the cornering thing when it's raining, just to make sure :)
So I guess the other R34 GTR owners don't have this switch? Maybe it's just a dummy switch installed for looks lol.
https://www.sau.com.au/forums/topic/255712-mystery-switch/#findComment-4409938
Could be a "Cheat" switch LOL!
Friend imported a R32 GTR and had this switch and when you flick it, it activates the brake lights, so when ppl are street or circut racing you and see you brake light flickering, they slow down, but you still keep going LMAO!
https://www.sau.com.au/forums/topic/255712-mystery-switch/#findComment-4409950
My Money is on Neons :)
ROFL.
Wow, that is such a dastardly evil invention! Would be great for those tailgating douchebags as well. I checked though - unfortunately it's not.
https://www.sau.com.au/forums/topic/255712-mystery-switch/#findComment-4409971
I wouldnt think it would be to turn off the immobiliser/disable... that would be a bit pointless having it in full view
It wont be a 4WD/RWD switch, you cant run a 34 in RWD without taking out the drive shaft (or you'll kill the transfer case)...
Stick your beaver under one or other side of the car and see if you can see something... cause im thinking neons too :happy:
https://www.sau.com.au/forums/topic/255712-mystery-switch/#findComment-4410105
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
