have had a bit of a look on here for some posts on brakes and there is plenty on calipers and brake pads but was wondering what sort of rotors you guys run???
not talking about big AP setups or any aftermarket set up, was more along the line of RDA's? DBA's? aero tech etc etc but still on a factory caliper.
not really important what car either but some will ask so there for a R32 GTR
really just any general feed back would be great
cheers
https://www.sau.com.au/forums/topic/255849-brake-rotors/
My slotted RDAs gave out on the track day, I gave them a floggin yes but I was told but others there that they won't last as long as the DBAs, different metals and manufacturing process apparantly...I've heard some say "they're from the same factory, so DBAs are just overpriced" and others just laugh when I mention that line so I dunno.
I've been through two sets of RDA front slotted rotors, next time it will be the DBA I don't see other track driven cars running RDA and that tells me there is either a reason or most track guys believe in buying brand name, considering some of the cars I've see at track days (low budget trailer hauled cars) I reckon it might be because of advice from others, make from that what you want...
My RDAs were shuddering by the end of a track day they were in their later life and I knew that they would maybe suck by the end of it but I didn't want to thrash the new set I had in the garage.
If someone can support the reasoning to buy DBA please shout it out...
https://www.sau.com.au/forums/topic/255849-brake-rotors/#findComment-4418992
Project Mu are good, cheap & available. They can be had in either a one piece or a hatted 2 piece rotor. They are much better than either the RDA or the DBA rotors. If you are going near a track I would recommend them. If you just drive on the road the RDA's will be fine.
I have had a total of 8 DBA 4000 rotors. They are sitting in a pile on the floor of the shed as 6 of them are cracked. As mentioned earlier it is the return slots that cause the problem. In fact I would (for track purposes) avoid any rotor that has slots that continue to the outer edge of the rotor. I used the RDAs for one track day only & they survived ok. I wouldn't recommend them for continued usage however.
https://www.sau.com.au/forums/topic/255849-brake-rotors/#findComment-4419627
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
    • I forgot about my shiny new plates!
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
