Here a tip. My Fiance says if you buy a $100 coles gift card it is all profit as they don't have to pay for product to sell, so Fire appeal gets $100 you get $100 gift card you can use to pay for your shopping instead of cash, then fire appeal gets another hit up of profit cash from your shopping!
Makes sense but not sure if gift cards are classed in this thing or not.
lol i dont think it actually works that way
Lol, neither do I, but it would be cool if it were true.
our work donated 100k and we have a fundraiser today as well and our HR dept has arranged for special payments to be arranged from peoples wages (whatever people authorise to be taken out (1 hours worth of wage a day or at whatever people specify) pretax to be donated.
We'll go to the coles one this Friday, then to the safeway one on the 20th plus donate about 100 cash.
every bit helps
spent $150 on friday night at caroline springs coles
also took me the missus and 3 friends to bunnings and made them all eat sausage sizzle from there as weel because the cash all goes to the bush fire thing . . . . . and any excuse to go to bunnings lol
We hit the local Coles, queues were big but am sure it was worth it. Will be great to get a final figure as so many other people were there for the same thing. I also set a deductions scheme out of staff pays at work too, either once off or payment reducing over 4 weeks. All for a very worthy cause.
I worked 9 hours at Coles on Friday and it was absolutely hectic. Worse than Christmas or Easter. Basically all the staff were at the service area all day, regardless of what department you were in. People went nuts too, bought like 5 years supply of tooth paste, etc. Saw several ~$1000 orders go through my register alone. I work at one of the bigger Coles stores, with 13 registers, and every single one (excluding the 3 express) had at least 10 trolleys lined up.
I will say this though, despite the monster lines that filled the fresh produce area, blocked the deli off and forced people to wait nearly half an hour to reach the register; no one complained. Everyone was in good spirits, polite, friendly and patient.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
    • I forgot about my shiny new plates!
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
