Ive been looking around for a skyline atm, heard different stories from people about how costly they are to run? if im not drifting dragging etc, i dont imagine itd be more then the normal car just for little things needing replacing here and there? or am i wrong?
cheers
https://www.sau.com.au/forums/topic/256790-skylines-a-good-reliable-car/
  • Replies 41
Get a tidy low K's Skyline and it wont be expensive to maintain.
Get a High K sh*tbox that has had the Ass Caned out of it and watch your cash vanish into thin air. They are fairly robust things but Any car whether it be a skyline or a ferrari can be a lemon.
Yes and no. They are getting a bit old now so things like bushes etc are gonna need to start being replaced, other than that I haven't had an issue with mine. Same as any other old car. Fuels the biggest one, its not too bad usually about 10.5L/100km unless your heavy on the go pedal then it can fluctuate as high as 13L/100km
Bought R32 GTST straight out of compliance, about 7 years ago.
Regular mtnce ( inc things like Spark Plugs / Timing belt ). Accessory type trouble only, like radio and some air-con probs.
Could'nt ask for better trouble free motoring.
I don't thrash it, and I don't nurse it.
I agree with the Yes / No
all depends on the cars service history and what its going to be driven like with its future owner!
Word of advice, if you buy one 'dont boost it up' cause they last longer like Jax said
i had no problems until some nub tuner boosted mine up, pretty much died in a month
Ive had mine 4 years and all ive had is a hole in a clutch line. the car is coming onto 15 years old now and still in excellent condition. like to see how a 15 year old commo or ford looks.
Edited by Pal
I replaced my clutch with a HD item and subsequently had the clutch pedal bracket snap, so replaced that.
Now I'm looking at replacing front CV joints and my bushes. Other than that no problems with it.
They really aren't that bad until you modify it, if oyu don't do the supporting mods then things will start to fail.
lol as high as 13/100kms .. I WISH. My r34 GTT drinks 16.5l/100Kms in city driving and that's not racing or being an idiot ..remapped ecu so its not running rich either. Original O2 sensor but its not showing any error codes - oh yea BP Ultimate only.
I got my 34 gtt and it had low Ks and was stock completely .. and Im starting to think it was a lemon, spent more than 2-3k in repairs alone in less than a year and now I've got whining/feedback through my steering wheel accompanied with loud scraping when I turn the sterring wheel... f**king getting tired of it.
Edited by Delta Force
Had my skyline for about just over a year now (bought it back ~ Dec 07), bought it as a stock one & I left it pretty much stock & had no problems with it other than the problems that it had when I bought it which was a broken A/C & cigarette lighter not working.
& I didn't really give it any special treatments, just do the standard service every 5000km & had the major one done @ 100,000km. Oh & I wash it occasionally when I can remember.
Fuel wise it seem to stay around 13 - 15L/100km but thats mainly city driving with alot of short trips & getting stuck in traffic @ peak times :D
Edited by Mayuri Krab
I have had my modified GTT for 2 years imported myself, had mods in Japan very tasteful and the guy seemed to look after it well. I have always given all my cars what for :( but i am very anal about servicing and i have never had a problem with any of them, it all come to maintanence and the right quality for the car and you wont have a problem.... Also get the right tunner to tune it if you want to power it up a little, i run 14psi off the stock turbo and never had a noise or problem...
I ran my R32 GTSt for over a year with an untuned 250rwhp, only issue I had was on the way home from a cruise one day I snapped the clutch fork pivot >.<
Was super fun, went hard and took a LOT of punishment.
Then I decided to get a little more serious :(
They are as good as any car.
The owners both present and past determine reliabillity.
What you do to the car , how you drive it
I would normally get 10L or better per 100km out of the old R33 gtst and similar with the R32 Gtst and R32 GTR's.
The tune and type of mods you do effect things, like any car.
Things like not going for super heavy sprung pressure plates in the case of clutches in R32's will prevent braking pedals etc..
There is plenty of good info on the forum about it all
If you are thinking you want to race and modify any car, then just throw your dreams of reliabillity into a nearby bin.
Well considering the stock GTT turbo is rated at 12.5psi MAX I'd say you either have a highflowed turbo or a non stock turbo or a BLOWN turbo and you don't even know it ;-) I'm yet to hear of anyone running more than 12psi on a stock gtt (non-hiflowed) for more than a little while without blowing it.
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
