Since these things (GTR's) seem to spend more time off the circuit than on it we should have a thread to show off your carnage!
Heres my first effort for the new car.
happened at eastern creek today in the wet but think it was partially damaged from oran park testing a few weeks back.
Front wheels were not driving very well after it let go completly.
https://www.sau.com.au/forums/topic/257137-gtr-carnage-thread/
  • Replies 42
Hahah thats right ben I forgot about this cars untimely habit of destroying running gear!!
That crown wheel and pinion came from my old GTR so its gotta be the cars fault.
Evocoop I agree but it is fun to look at other peoples desruction. If nothing else it makes me feel better knowing im not the only one.
Ill post photos of my smashed JUN oil pump and snapped crank shaft latter thats worth a look see.
Kinda resembles your bottom end!
Just wait till Duncan makes a showing with his trail if destruction
Edited by Risking
He will place so much load on the server with his posts in this thread that the entire sau server will go offline for 2 days :)
No baby photo albums at duncans house, just albums full of broken rb26 parts...
Gee's Brad didnt know that happened, sorry to hear/see :D
Must say though, the your new GTR does look and sound and go bloosy well mate, its a very nice car!!
Thanks Chris.
We weren't expecting to find a lunched pinion but thats the result!
Oh this is going to be a good thread :)
I agree. Should be a few nasty items people have broken floating around
Ok here we go.....these arent as bad as bending a rod 90 degrees, but just like any other broken part in a GTR they've been expensive
Launching; (done a few driveshafts now)
Here's my first motor gone;
Oran Park GP
For the life of me i cant find the pics of the second motor going at wakefield, but yeah - lots of oil on the outside of the sump, you can imagine the rest
Brad if you can please send me the tank pics that would be great
You owned one of then ben and its still breaking....
I remember that clutch, was pretty funny weekend.
Ill have to upload them latter and send them to you steve. I found a few better ones of the inside as well.
I have a cardboard box full of bearings that we used to pull out after 10,000K's just to be on the safe side.
Its amusing the parts we keep that have broken.
I still have my broken oil pump and crank somewhere. A few destroyed rods and blocks. multiple gearboxes with holes in them and now front diffs.
haha nice work Brad. "there's your problem!" too much power :wave:
just run without a front diff like John does.
BTW I've got nothing to add to this thread. Other than a few motors (nothing as impressive as coops) the only things I have broken are caster rods - broke 2 of them at different times.
Im not sure if power is to blame Duncan.
We've actually taken a power reduction of sorts trying to gain alot more midrange. Which could also have killed it.
That gear set did over 2 years worth of racing and who knows how much before that.
I think it was our tinkering with the ATTESSA controller (Haltech E11v2) which killed it. Plus the massive slicks would not have helped.
    • Assuming the current ECU is stock, it might be worth getting hold of a nissan data scan cable. It could be as simple as voltage at the ECU
    • You need to test for spark when it matters - ie cranking. Kill the fuel supply, pull a plug and earth it, set up a camera and go crank. The spark needs to be consistent, every other turn of the engine. Not some sputtering of occasional spark. The reason I say this is because spinning the CAS in the air is not the same as spinning it installed, and if there is a bearing problem in it, the disk might work differently in the air than in the engine. You won't want to try to set the timing unless you know the spark is happening right.  Also, reconsider running the R35 coils against the stock ECU. They like a different amount of dwell cf the originals. It's not massive, you can actually run them, but it is better if you can adjust the dwell (which you can with Nistune in the stocker, or with an aftermarket ECU). Besides any of that - when you had the multimeter out, have you got power where it needs to be, earth where it needs to be (and when, in the case of igniter triggers), etc?
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
