Ok so it's come to a point where i really probably need to spend a bit of cash on the ol RB20 to keep it running reliably.
i.e Coilpacks, Timing belt, water pump, idler/tensioner pulley etc etc.
So i was considering an upgrade rather than sink my cash into the RB20.
Heres basically where I'm at. RB25 or SR20.
Let me frame the case each way. First of all I guess its important to point out that it's street driven on a daily basis, in traffic, and i do NOT want to be doing that with 400hp. I'm thinking around 250rwkw (Tops. Probably more around 200.) with response being the key. I do however intend on getting into a bit more circuit racing and maybe some drift events soonish. Trying to set it all up first.
Now that i've mentioned that onto the two choices.
Rb25
Pros
-Can keep the ATTESA system as long as i source it from a Stagea and run a GT-R power fc. (So I'm told.)
-Relatively cheaper if i keep the RB20 Box (Should maintain 200kw?)
-Good mid range and a fairly common swap into 32's meaning info and support should be readily available. (Ideally)
Cons
-Heavier.
-Have to get one from a Stagea or can i just get the stagea front diff/sump assembly and bolt it up to a standard rb25? Also am i gonna run into issues with my rear diff being 4.3? I THINK Stageas run 4.1? Should i just upgrade my rear diff to a GT-R item? Also running 4.1 from memory.
SR20(Please note with the SR i wont bother trying to keep the ATTESA and will just rip it all out.
Pros
-Lighter (Sr<RB in terms of weight, plus the weight savings of removing the transfer case, and front driveshafts and diff etc.)200kg?
-Better for street use being smaller capacity and easily tuned for the power range im thinking about (Yeah sounded dumb to me as well)
Cons
-More expensive as i will have to run the sr box as well, S13 Crossmember for the engine, and im not sure about the geearbox crossmember.
-Removal of Attesa means it might as well be a GTS-T
So i guess thats kind of where I'm at. I know theres a bit of infor on RB25 swaps and Im sure I could find some about SR swaps too, but I guess my case is probably a bit more peculiar being a GTS-4. I'd rather not go down the path of RB26 as I dont need the power that they entail.
Can anyone shed any light on what either swap will entail and what they think would probably be the better solution.
Cheers,
Greg
https://www.sau.com.au/forums/topic/257193-r32-gts-4-engine-swap/
Just briefly, based on my own experience fitting the Stagea engine:
The Stagea diff ratio is different to the GT-R (4.083 vs 4.111) You can either swap the diff from your RB20 into the Stagea engine, or swap the Stagea rear diff internals into your R32 rear diff. I initially did the front swap, then later swapped to the Stagea set (RB25 just has too much torque to require 4.375 gearing). If you run Stagea gearing, replace the speedo drive in the gearbox with the GT-R item.
I'm almost certain that the Stagea sump is not a simple bolt-up to a RWD RB25.
The original R32 gearbox seems more than capable of handling the torque. When mine was first tuned (Wolf 3D v4+), I was pushing 180 awkW (easily in excess of 200 rwkW).
Rb25
Pros
Cons
-Heavier.
Pros
Cons
Cheers,
Greg
My opinion - it would be cheaper and quicker to get 200kw out of your present motor and then save up for a R32GTR or R34GTT!
if u put in an rb26 ur gona have the power u want with only a couple of bolt on mods like exhaust, cooler and abit more boost.
in my opinion it would work out cheaper seeing that it would be a much easier swap and your not going to have to buy as many parts to achieve your power goals
apart from all the headf**ks putting them into an earlier model car (It might be a tad easier on a R32 but I've seen it done twice on HR31's and both times, the actual fitting of the motor was fine, but getting it all up and running was a long and drawn out process)
I guess it's a little more involved but have you thought about going down the path of a 25/30?
I'm not really an expert on rb20's but I think you'll require the sump adapter which are about $600, an rb25 head and associated intake piping but the turbo manifold & lines should still all bolt up fine (you have to stretch them), probably also a new dump made up (or modified) and the vct line tapped & a new timing belt..
I'm not sure but I'd say the existing rb20 sump should bolt upto the sump adapter, if not rb26 sumps are pretty cheap to come by and the diff can be transfered across :)
Just a thought really - In my mind it sounds a better option as the parts are alot easier to come by!
Anyway best of luck with it!
It's not that i don't have the money for a 32gt-r or 34GTT its just that i dont want them.
Blind Elk- Do you have any more info on the swap? Any pitfalls etc? Feel free to pm me or send the details through to greg.dekwant(at) gmail.com, I'd be grateful for any insight you could give me. Cheers.
The main pitfall is retaining ATTESSA. If you are going for an aftermarket ECU, get a PnP GT-R version.
Other than that, it is a simple bolt-in proposition.
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
