Any ideas on what sort of flywheel torque figure I might get from:
RB26, stock bore and stroke, Tomei 280 degree 10.8 mm lift cams, pair of Garett 2860-10 turbos on ported stock manifolds, head ported on stock valve sizes, stock size ported TB's, Siemens 800 cc injectors, Tomei cooling gallery pistons, 8.5 to 1 CR, Tomei rods, steel crank, N1 block, mapped on both pump and 118 octane race fuels, running M800 Motec. I need to see what I need gearbox wise. Engine is going in a 2WD car. Thanks.
The strength of a gearbox will never change but it depends on what car you are putting it into. Put it in a Datto ute and you can probably double the torque going through it.
For that setup, considering torque is usually relative to hp, you will most likely top out at around 700-750nm. The setup is not really capable of much more than that but put a bigger set of turbos and bigger injectors and that figure will go up
In real torque figures 550-600 wheel NM. A 7.2 litre cat diesel makes around 800nm atw now way you will reach a tonne.
Edited by URAS
How does one double the torque output of an engine by putting it into a lighter chassis?
You don't. What I am saying is that the torque required to break that gearbox will change depending on the weight of the car it is in. If it's in a datto ute it will require a lot more torque to break it than if it were in a 4 tonne truck.
Before this turns into a bun fight, I did ask for a torque figure at the flywheel :ermm: Units we are measuring in will help, I am in the UK and still work in Imperial (lbs / foot torque) so need to convert :) Cheers.
    • Sorry, are coilovers ACTUALLY ILLEGAL in NSW? They aren't in Vic, as long as they retain 70% of stock travel and the car is above 100mm off the ground. Does NSW actually have a law making coilovers actually illegal? RWC/Blue Slip/Engineering people not knowing the actual f**king laws boils my blood. Demand them to point to the documentation that states a coilover is illegal. (it may exist in NSW )
    • But seriously, can we ask for the results of the "tip a bottle of metho into a nearly empty tank" experiment?
    • Hang on. Let me get this straight. The desire is to have coilovers, BC in particular, to be MORE comfortable on Sydney roads than stock suspension? Well, that's obviously not right. BCs have crude damping design at the very best, and typically hard spring rates. BC stands for Billy Cart. And then, the desire is to put in some shitty old worn out stockers, to get it blue slipped and then put the BCs back in? And then.....what? Not worry about getting pulled up by the Plod? Because you seem to have raised a worry about paying for engineering (which actually does solve all your legality problems) and still getting pulled up.... but the only problem there is that if/when that happens you have to show your paperwork at the inspection station. Whereas, if you just swap in borrowed shitty old stockers to get it slipped now, and then you get defected in the future, you have to go find more shitty old stockers then too. You course of action looks like this set of options: Buy brand new stock type dampers, and springs. probably cost a bit more than $1k all up, but will last for the remaining life of the car. Put them in, pass inspection, drive on them forever more. Hell, they could even be really nice Bilsteins and Kings or other lower&stiffer springs if you wanted. Get the car engineered as is. ~$1k. Buy new Shockworks coilvers (or MCA) and also pay for engineering. You're spending a lot more here. But these will be the best things that you could drive around on.
    • Might be worthwhile hitting up Facebook's groups, I know most of them contain terrible people and scammers - however you might be able to find someone that's in Sydney with factory suspension you could purchase and/or hire. Just do not send any form of money anywhere, in person cash only.
