Damian at Grafico.
grafico.net.au
he does all the stickers for the supercarclub (p1) and did all our Dutton Stickers and the 6 hour stickers. His stuff is quality.
there is an asian dude at Carribian market
I use CarX for all my vinyl graphics. Call Kevin on 0422 127 847
He uses quality 5 year vinyl.
65 Whiteside Rd,
Clayton South, VIC
you guys are the best thanks for the quick help. any you blokes racing the haunted hill hillclimb??
hey crew anyone know where to get large custom made stickers? looking for something to put on my van have a design need someone who can print it up or make me a vinyl. cheers
Send me a PM, I can help you with vinyl graphics but don't do any printing. Some of the smaller vinyl graphics examples at jdmstyledecals.com.
there was a euro looking dude, also a bogan looking dude at one stage. but last i went there only the asian guy with his sun, and the GTR badges and so forth
LOL! You mean his Son... Yeah I do remember that, had all the APexi, BLITZ, GReddy, HKS and cheap fake badges.
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
