hey im a new user wasnt too sure where to ask this so il put it here
i dont no much about skylines and need some advice on wether this is a good buy or not
im looking at buying a R32 GTS-t auto
engine is very stock
standard wheels
paint is average with a large spot of clear coat peeling off around fuel flap
chrome on the front grille and other places is also peeling off
the interior is pretty shabby also the steering wheel leather is coming off and there is a reasonable amount of rips in the seats
hes asking $6000ono... cheap for a 32 ...but considering the interior and paint is it worth the money?
just loking for some opinions from people with skyline experience
https://www.sau.com.au/forums/topic/257469-r32-gts-t-for-6000/
Condition of the interior is meh, can always just chuck GTR seats and a Nardi in and theres the interior problems you speak of sorted. Paint would be a bit of an issue if you had no plans for tracking it or a respray later on.
Just check everything is aight mechaincally, as thats where the dollars are if it fks up.
Edited by AndrewJZX100
if the look like its in pritty bad shape i'd have to question the condition of the engine and suspension arms/bushes.
6k might be cheap but i think if you really want a 32 save up a bit more and get one that is in better condition, i know i'd be happier with a car that has good paint and interior.
If your a mechanically minded person who can spray paint fairly well and can get contacts for parts then this sounds like a nice project car.
That said I am with QWK32, if the exterior is bad, the interior is bad, chances are it will have received very little care and attention. Buy it knowing that your going to have to fix something and keep a slush fund just in case. Alternatively spend the slush fund on a better car - your call.
poor thing
seen better days
just waiting for someone to feel sorry for it
...but ya never know! It might be just sun-damaged. The engine might be like new! Services all done? No rust?
Motto:- BE CAREFUL
thanks guys, i really couldnt find out much about the car when i went and saw it because the owner lives out in the country so he left it at his brothers house for people to come look and he didnt no squat about it apparently the owner is an engineer so he probly knows what hes doing to the engine if he thrashes it
its a 2door
the owner said in the ad it has all service reciepts
my uncle owns a panel beaters..but not sure on how cheap hed respray for
i checked the rear mudflaps and there was a little rubber there... (from burnouts)...but could have been his brother thrashing it just the one time he drove it
i think i might say to him if you get desperate il offer $4000 because i cant justify paying 6 for sloppy cosmetics
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
