On my way back to the office yesterday on Chesterville rd, there was just 2 cops random breath test. I pass the breath test but the cop decided to ask me to pop the bonnet I got done for having a BOV later he also decided to fine me with the exhaust without even testing to see if it is over the legal limit. Are they allowed to fine you for this? without asking you to go and get it tested?
https://www.sau.com.au/forums/topic/257525-defect/
he can defect you, however he can only suspect that your exhaust is too loud, and can issue you with an epa notice, however as far as i know, he is unable to actually fine you for the exhaust... are you sure you didn't recieve the fine for the defect (bov)
https://www.sau.com.au/forums/topic/257525-defect/#findComment-4431662
That's Victorian law.
They can just report you willy nilly without proof, evidence or otherwise.
If your exhaust is legal (when you get it tested) IMO lodge a freedom of information request to the EPA, get the officers name, number and so on and take him to court.
They law really needs to be changed so that they cannot report people without fact.
https://www.sau.com.au/forums/topic/257525-defect/#findComment-4431696
Thats why I hate aftermarket BOV, they are pointless and just give noise and you already have the stock one.
I remember you car is pretty stock except for the FMIC, Boost controller and Exhaust, so you probley won't have to do so much work to get it cleared.
I suggest you put your stock cat back exhaust on and get the defect cleared.
Wait about a week or 2 then if you get a EPA notice you gota take your car to the EPA so they can test your car is quiet / meets the correct db levels.
In which I strongly advise you to remove the BOV and keep your stock exhaust on!
All the best!
https://www.sau.com.au/forums/topic/257525-defect/#findComment-4431832
Well guys i failed the test it around 100db @ 5k rpm. The guy said he couldn't give me a epa cert, since i've dont have a epa letter. So i need to borrow a stock r33 s2 muffler if anyone has one that i can borrow for a week or so i would appreciated.
https://www.sau.com.au/forums/topic/257525-defect/#findComment-4431930
you wouild need an epa notice to get it filled out to actually clear the defect if im not mistaken. i think vic roads sites it in order to remove the defect. I'd say you may be getting one in the mail some time soon.
100db is mega loud considering you just replaced your muffler. I got 96 with 3" turbo back with hi flow cat on my dual exhaust. I can reccomend a listed tester once you fit the stocker back on.
https://www.sau.com.au/forums/topic/257525-defect/#findComment-4432140
lol 100db @ 4700 (4700 is the test point from memory)... thats fairly loud so i can see why the officer will dob you in.
You didnt get a on the spot notice did you?
Because you'll be getting one in the mail (EPA letter) and THATS when you go get it tested.
You might as well take this opportunity to put a stock or GTR BOV on (i have some for sale :wave:)
And also get the exhaust back to a more reasonable level to avoid such attention again
https://www.sau.com.au/forums/topic/257525-defect/#findComment-4432156
i got one you can borrow.
https://www.sau.com.au/forums/topic/257525-defect/#findComment-4432367
If its the same as my defect you can drive the car as much as you like untill the 25th and after that date you can only drive it to a repairer or vic roads for another 21 days then the rego gets suspended.
Also is it a major or minor defect, will say on the defect notice, if the exhaust is on the defect notice then you have to get it fixed before the defect can be cleared, go to who ever your going to get an rwc through (assuming its a major) and see what they want you to do.
The fine will most likely be for driving and unroadworthy vehicle.
https://www.sau.com.au/forums/topic/257525-defect/#findComment-4432625
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
