I'm going to have the same problem, as my R33 gearbox mount is about 150mm further back than standard.
I am making a "C" type mount that carries the original g/box mount on a box section piece of RHS having about 4 mm plates going back to the original mount points braced with a web section fillet.
Just have to get under it and design it, put it on paper and get someone, any welding/pressure vessel shop to make it for you. About any Sheet Metal/Engineering Shop will be able to point you in the right direction if they can't do it themselves.
ok, cheers for that mate, ill let you know what i come with :D
i also thought about dropping bolts through the floor so the mount lines up with the xmember... ?
  • Replies 2k
If you do that, make sure the holes are reinforced, because with continual driving and some hard launching, they will tear out of the floor, making a bigger problem than the initial one you have now.
Might be better to use the orig and mount back to them
ANYTHING will fit if you try hard enough.
I put my SAAS seats, on a piece of 12mm aircraft grade aluminium sheat and then mounted the runners to the same sheet, that way I still had some adjustment front to rear.
I removed the height adjustment as I needed to lower the seating position about 100mm to allow me to sit in the car with a helmet on.
I am going to experiment with R31 seat tracks, as the height adjustment is on the track and not in the seat.
I have a set (pair) of Z32 import seats if anyones interested, they have a fully electric drivers seat. forward & aft, height, lumbar, and wings. Would have to make up mpunts as they are a very narrow seat.
Mike,
Do you presently have DR30 rear brakes?????
If yes! they are identical to Z31 300ZX rear rotors.
If you don't want to buy NEW, find ANY wrecker that has Z31's.
Are the rear z31 calipers similar to DR30?
Mike Cash - how did you go getting through regency?? or have you got any more info on what you would need to do?
ghostrider: im assuming that z31 rear dics would be the import old rb20 z31 or the aussie one, or are they the same size?
nah i got the dr30 rear end on mine at the moment and my dics are undersized from ever use.
as far as regency goes, aparently all you need is the same dics size as a car that had an rb20det. in my case i used r31gts fronts and dr30's rear and other cars have been passed without any engineering certificate or anything.
Will S13 seats fit - i got a set for free.
Measure the rail spacing. I measured a set up for my R31 (which may or may not be closer in design) and the S13 rails were about 45mm too far apart - the R31 centre to centre of the rails was 415mm where the S13 was about 460mm.
What or how do you call an DR30 HEAVY???? What are you comparing it to???? Maybe compared to a Mini, but to another Skyline, it's one of the lightest. DR's max weight 1250Kg, R31's OZZY sedans 1600Kg, HR31 coupes 1350Kg. How you say heavy????
WHOA! where'd you get that weight from for the aussie R31!?!?! I weighed mine with 40l of fuel, spare, tools, jack, assorted crap and full trim and it was 1280kg on an extremely accurate weighbridge. Mine is a "stripper" model GX though, with no luxo bar power steer and aircon, with basic trim, and its manual.
All reports I've heard peg the HR31 at closer to 1400kg, on the + side....Especially for the sloppy fat bitch Passage's...
my epic adventure is comming to a close, pick up the rims with new tryes tomorrow morning went for falkens ze512's 225/50 on the rear and 205/55 on the front, pick up the front seat, new tacho and boost gauge on sat then its fix the lights and shes ready for engineering!!
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
