That DR is for sale.
Ben Ellis had it at the IDA drift day at Oran Park in Feb this year.
You have the best CAM maker in the country up there near you, Tighe Engineering, they made my n/a cams, brand new, just needed my stock cams for samples to cast the billet blank.
Cheers,
  • Replies 2k
do you mean as in ivan tighe?
Sure do!!!
He made our RB26/30DE hybrid cams.
The wildest duration, over 350 degrees each for the princely sum of $840.00 pair.
When searching around, HKS, Trust, Tomei etc were all that much & more EACH and could/would not supply bigger than 284's.
Cheers :ghost:
Sure do!!!
Cheers :ghost:
damn thats crazy!
i've driven a r31 gts-x with the nics red top and there was nothing there to make me smile in my eyes my rb30e goes harder, from memory the nics red top was only 20hp more than the l20et, to its defence though it was the very next 6cyl engine nissan produced after the l20et, silver top has 205hp at the fly same as the intercooled fj20, produces around 15 more Nm at 6500rpm and with around $2500 in mods should produce around 160rwkws, rb25 turbo and remap 180-200wrkw, vg30 turbo and remap of stock ECU 200-220rwkw...parts and upgrades are at your fingertips from a range of places!! my two cents...
Was it an auto GTS-X by chance? The NICS RB has 180hp if I recall rightly,and the L20et had 145hp? Auto kills the NICS,but 5spd isn't much better. You must have had a freaky RB30E if it went better than a manual RB20DET! I've owned both,and know what I'd prefer.Not that I particually like RB20DET's either........
once the turbo runs at full rpm (silver top makes full power at 6500 engine rpm)its not going to produce more power so the only way to go faster would be to change gear
Yes,I am aware of that :D I was commenting on their ability to rev more than 5k.
No thanks, Butchery is not my stock & trade.
I meant with the proper machinery, ie a lathe, hence its not butchery but a modification....if you arent into modification, why are you messing with adj cam gears?
no offence
A GTS2 RB30E is good for 145Kw at the fly.
Yes,I am aware of that ;) I was commenting on their ability to rev more than 5k.
i think it was just a sh%t example of a gts-x :D
Hey Guys!! Got my clutch and all that in now, she's sweet as!! Ran my water lines to my turbo, thats sweet as as well just need my hose clamps for the oil return line and the turbz is finished!! Then i need to find my panels :bs!: and its almost ready to go!!
As a quick question, what do u rekon a stock DR30 Fj20 exhaust manifold is worth selling for???
hmm my mate has a gts-x, its got a deep dark secret under the bonnet though!!!
silver top rb20det eccs, with nics finned red rocker covers!! highflow turbo, fmic, mines ecu
the bloody TPS has shat itself though.
that car does sound amazing even with a stock zorst, incredible spool noise. catches many unaware
meet a guy at the last massive skyline cruize here on the coast with a gts-x that had a rb25det under the bonnet.. now thats a kicker!!
    • Even with the piston at TDC there was room for it to drop, but I don't think it can drop fully into the cylinder, the problem you have is that you need something pushing against the valve to hold it up so you have enough room to put the new stem seal on and the spring etc.  I used compressed air only because putting rope in the cylinder seemed a bit risky to me, I know people have done it countless times before like this. Overall it's a pain in the ass job. Honestly you'd probably be better off taking the head off because the risk of dropping something in the engine and the finicky-ness of it all is very stressful. If you are going to attempt it though i 10000% recommend a 36050 valve spring/keeper tool. I had both the traditional lever type and after doing 1 cylinder it was absolute pain to get those valve keepers in place, even with 2 people. That 36050 is amazing, you do have to push hard to get them in place but it works perfectly almost every time. Back to my actual issue I think my engine is just tired and old and the rings have gone bad. The comp numbers (cold, no oil) were: Cyl 1 -129psi Cyl 2 - 133psi Cyl 3 - 138psi Cyl 4 - 137psi Cyl 5 - 157psi Cyl 6 - 142psi   Cylinder 5 and 6 having the most carbon on them.
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
