hey peeps, im hopefully about to be the proud new owner of R30_turbo's car.
for a refresh its a '84 Paul Newman L20et
anways, im wondering what simple things can i do/change to make it more responsive?
ive notcied that the stock AFM is highly SMALL and restrictive. what can i do about this? will a Z32 AFM simply bolt on? like one of the 80mm ones or something like that?
  • Replies 2k
more free flowing exhaust is a great start, 3" all the way....with the afm swap you might find that there would be other things involved that would = $$$ a new programable ECU to work with the afm, stick to the basics as they work
1000 posts woops....
As capacity increases height increases as i think they keep the same/similar bores just longer stroke. although i can't confim for L20A's cos ive never looked at one.
IE if you mix and match a LD28 (diesel) crank to a L28 block with something like L26 rods and KA24 Pistons you come out with a L31
i have a program for 6 cylinder L series engines at home which calcs comp ratios etc from mixing diferent parts etc
As a matter of interest! does anyone know the differences of L series 6 cylinder engines?
Is their hieghts the same or does it increase as the capacity increases?
How far can the L20 be stretched etc, etc.
Only befitting that you posted it, as you did start this MARATHON originally.
But back to info, 3 inch would be to big I think, the exhaust guys roughly work on 1 inch per litre + 50% for turbo, so if it's mandrel bent, 2.5 would be plenty, but if press bent 2.75 would be the go, as the restriction in the bends is the resultant flow rate. My Paul Newman exhaust is a press bent 2.5 and it flows easy.
As for flow meters, I would look at Series 1 R31's, as the air box arrangement is very nearly identical, I know it's not turbo, but it is a 3L engine, or source an L28ET from Japan.
And further to my previous post, can you get 2800 from the L20 block by stroking with 280Z crank & rods.
Cheers, :ghost:
are you talking full rebuilt to increase the capacity, some of the n/a z car L28 engines run 3L+ capacitys, its the block your talking about is'ant it? looking back phat mr30 answered quicker...
Next question:
Is there size/capacity casting marks on the block?
If I wanted to make my PNV a sleeper looking all stock & standard, could I get an L28 block & change the engine numbers to L20 and get away with it, or has it L28 on the side.
Next question:
stamped into the block i'm affraid..not the eazyist thing to find though..
Cheers, :ghost:
yeah the car already has a 3inch mandrel system all the way thru fromt he turbo.
so if i were to get an AFM from an R31 it will theoretically just plug in and bolt on, crank engine and free-flowing fun?
If it has the STOCK T25 turbo on it, source yourself a T25 from an FJ20DET. To look at, they are identical in evey way, they bolt onto the manifold the same, oil lines etc, all the same, just rear housing is 0.68 instead of 0.37 standard.
It will spool up easier and faster and supply more boost, but should be intercooled, even a little one, if boosting over about 6-8 lb.
FJ20 came with a T3 as standard, best to my knowledge the first T25's were on the CA18DET....
Next question:
yeh they have L28********** stamped on them in the usual position.
bear in mind mine was originally an l24 and now its a l28 no mod plate nothing, just notified the rego department?
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
