Since i've bought my r32 gtr its been a lot more laggy than my mates, its not really full boost til 4500-5 and doesnt kick in that hard
My mates seems to kick in real hard down low, about 2500 from memory
Mines still stock turbos but its got adjustable actuators on the turbo's, ive adjusted them to run 10 psi and there seems to be heaps of pressure holding the internal gates closed, one thing i noticed is it hasn't got the boost restrictor in it but only runs 10 psi maybe still the actuators are adjusted wrong even though theres a lot of pressure keeping the gates shut?
It also has a big cooler but surley that wouldn't cause that big of difference in lag!?
Its got stainless dump pipes that go to a 3.5 inch exhuast not that i see how that would make it laggy lol...
apart from that its stock
Any ideas?
cheers
https://www.sau.com.au/forums/topic/257782-gtr-too-much-lag/
Might be worth putting some stock actuators on it then? but there seems to be heaps of pressure to hold the gates closed!
Full boost by 4000? wonder why my mates spools so quick then, his does have adjustable cam gears but i didnt think it would of made 1500 rpm difference
If your mates one has adjustable cam gears that may explain why his ramps onto boost harder and faster.Cam gears properly dialled in can increase low end and spool up.not too sure as to what extent however
hey mate, same kinda thing i found with my gtr stock everything except for zorst, full boost by 4000rpm atleast, not a reall kick in the back either... untill i boosted her to 15pound, made a world of difference,cam gears are going in atm so hopefully that will help lag.
but yeah adjustable actuators on stock turbos not so sure, maybe put factory ones on and save ur self time mucking round.
ball bearing turbos help too.... :)
FWIW my stock turbos + EBC make 13 psi by 3300rpm, but has Nistune. Saying "full boost" without quoting the boost level is meaningless because the higher boost the longer it will take to get there... but yeah 10psi by 4500 is no good. I'd try a set of stock actuators first.
byebye - Did I fit cam gears to your friends GTR? That will make a big difference..
I would suggest getting it tuned/diagnosed properly.
Sam.
Cam gears were already on it but you played with them, its the blue sparkly/dented one you tuned at munros before power cruise
The timing was out a little bit and has made it slightly more responsive
When are you coming back to tas sam? nath did ring you one day but you sounded busy, you said something about him being a pest haha
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
