Hey,
Just wondering if anyone knows if you can remove the PS and AC from the side of an RB26 without having to drain fluids/release gas and take off piping first?
how many bolts and where are they located etc? any help would be greatly appreciated!
thanks for your time in advance
https://www.sau.com.au/forums/topic/258042-rb26-engine-removal/
yeah, but how do you take it off?? were having trouble finding bolts =\
Edit: thanks Carl, had a look around, but all the guides say to drain/release and the manuals have SFA on how to remove the ac/ps
Edited by Fishpaste~
its a lil differently laid out to 20/25 setup, hence where we're struggling. ive lifted 3 or 4 RB20s out of various cars, i was assuming it would be the same, but the pump brackets etc are different to the rest of the RB engines
Carl / Blue32 - if either of you are able to drop around today and give a hand, im sure beer / favours would be paid :P southern area haha. Its being done in my shed
Will pop my head back in here during the day to check up
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
