I have played a little but there is so many wankers that don't want a fair match. Had one guy last set the match to 1 round 30 second timer, he just jumped in got a few hits then backed of and blocked till time was up. So f**kin lame
Ah man! I F**King hate that! :P
I was at Crown Casino and me and a friend were fighting around each on one Street Fighter 4 machine, while were in the middle of the game this F'ing Kent challenges us and he uses Chung Li, pulling off cheap shots.
Then we started kicking his ass then he pulled afew more cheap shots, started backing off and blocking then he ran down the clock.
End rant... LOL! :P
They way I play Street Fighter is, no timer and a full 2 rounds till one is KO'd and then a 3rd/Final round if needed.
Harden the F**K up Kents! :P:(
What happened to throwing a chronic blocker?
Aww damn, got this game on the Xbox 360, gamer tag is pitoui69.
I've got a few ps3 games, resistance 1 and 2 and gt5 prologue.
My ps3 tag is pitoui69 so add me if you want to play me in one of those games I have.
  • 5 months later...
Hey Guys,
Add me if you guys want to verse in Street Fighter,
ID is "rj34gtt", i come on around 7pm>onwards..Most of the nights..
  • 6 months later...
i used to play on ps3, now on pc occasionally. If you want to find good players, go on ozhadou.net . Should be a thread in there with a list full of players.
Does anyone here still play?
I recently went to an Ozhadou Box Hill tournament in Melbourne for a laugh, came top 10 so that was alright for a first-timer lol.
There is a tournament at Crown soon, first place is $1000, second place $250. But it costs 25 dollars to enter...
http://www.ozhadou.net/forum/viewtopic.php...736&start=0
And.....I'm hanging for Super Street Fighter 4! April Release date in Aus....
Dudley FTW!
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
