Hey guys
Quick question for the guys running more than usual boost; what brand clamps do you use?
At 7500rpm in 3rd yesterday one of the pipes blew off the rear turbo, which is quite annoying to say the least. So instead of just putting it back on and having it go again, whats the *best* clamp to use? Also, from experience what boost have you run without pipes blowing off?
Here's 2 i found that look decent, from what ive read since yesterday the wiggins ones are the best - discuss :P
  • Replies 60
Tried most of them except the wiggins. Too pricey for my blood.
The best clamp for money is the Norma high power. It looks like any other worm drive clamp but you can really give it to it with a socket and ratchet without it stripping.
The problem with some of the bigger tbolt clamps according to one hose guy I spoke with is they spread the load over too wide an area and end up with less clamping pressure.
The norma being a narrower band bites down harder on a more concentrated area for better grip.
The other clamp I have used albeit only on the air intake side is one I found at super shit a couple of weeks back, Its a billet alloy clamp hinged in 3 places. According to the blurb the hinges allow a more even spread of pressure around the diameter of the clamp. Its working fine where it is so I am going to grab another and try it on a cooler line where theres a bit more pressure. They look neat too.
You know those typical worm drive ones are single use only right? (not that anyone uses them once...)
If you dont have a ridge on the pipe for the clamp to sit inside of, its going to suck.
And yeah, the wider they are the tighter you have to do them up.
Most of them yes but the norma high power i have reused may times with no issues.
I found these ones on eBa which are pretty similar to yours.
Linky; http://cgi.ebay.com/ebaymotors/PEGASUS-TUR...sQ5fAccessories
I wonder how they would go.. But as others have stated just make sure you have a decent lip on the ends of the pipe and you should be all good.
I'm using those for my radiator hoses - pirtek sell them for more like $15+ each. You have to do them up a lot tighter due to the width...not really a problem with the hex head tho.
+1 on a better lip
I have "flared" my pipes and i use a single t-bolt clamp on each side, i have never had a pipe come off and thats with near on 25psi of boost. If the pipes werent flared, even with the best clamp on the market the pipes will still pop off. I would never run cheap china worm clamps, but i have seen plenty hold up to 18psi for years.
Steve you probably need a better lip on the pipe as opposed to some over the top clamp :)
Agreed :P
My mechanic welds all his ic pipe lips and i have never had a pipe blow off.
He has also run up to 34psi on his dyno r33 and Drag Vl; using the general worm drive style clamps
I've started replacing all of my worm drive clamps as they fail with T-bolt items - you have to really tighten the buggery out of them but they hold! I had to get a mate to weld ridges onto my metal piping onto the turbo after the silicon join just kept sliding off no matter what though, made a huge difference with 18psi going through it - I've gone from about 5 vacuum leaks to one which is only needing to trim the pipe down to fix!
The only thing i find with "tightening them as tight as you can", is that they seriously start to dig into the rubber/silicon joiners hard. The leave huuuge indents and start to tear :P
And having a ghey RB25 with the Jpipe you have to remove it often to get to plugs/coilpacks easily ha
I actually have less probs with the joins now due to the fact that the new clamps are roughly twice as wide as the old, and there's no perforated bits on the clamp to dig into the silicone! J pipe is a pain in the arse since I change plugs every 5-10 000km, but I replaced the throttle body join with some really expensive hose, which seems to not be as prone to leaking as the original join.
got a couple of those on my intake, as they were the only ones i could find in 100mm at the time. where it bolts up it pinches the joiner a bit and would probably leak under boost, hex key bolts are a bit gay aswell. do the job and fairly cheap tho
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
