v35 paul - did you do an ECU reset when you installed it? maybe hence why the stock one is trying to "learn"
and on another note-----
is there any difference between the CF Z-Tube and the stock Z tube item? (besides looks of course) im mainly talking about quality etc. is the CF real carbon fibre or just an overlay... etc.
-mark
Edited by BLISTC
  • Replies 94
Posted Images
-mark
Don't know how to reset the ECU.
The CF Z-Tube would have less heat soak then the stock Z tube and and any metal tube would have the more heat soak over time.
  • 3 weeks later...
So this morning i woke up and UPS man was at the door with a parcel.
Finally the Carbon Fiber Z Tube i had ordered 1 1/2 weeks ago had arrived. I ended up ordering it from www.thezstore.com and it was $195 AUD delivered at the time the exchange rate was around 75c
The Z Store's tube is actually sourced from www.evo-r.net but they are cheaper. Evo-R.net are the manufacturers of this Z Tube. It is made from real CF and it is really well made as well. I peeled off the EVO-R sticker which came off pretty easy and left no residue. I like it to look clean, and with under bonnet temps this sticker will just fall off over time anyway.......
I went to work and got home around 11pm. I couldnt wait and seeing how easy the DIY was i decided to attempt this install.
It was a fairly simple and straight forward install. 15min later and i was done!
Finished the installation...... dammit i need to clean my engine bay!
and here is the picture of the part it replaces.......
see it is just not all for looks, these things actually increase the air flow, due to the stock part having so many resonators for noise etc. and hence provide a very minimal increase in power (and they make lots of induction noise now too WOO!)
I really like doing DIY...... it feels very rewarding once the job is done (especially for a n00b like me) :)
-mark
Edited by BLISTC
-mark
EXCELLENT write up i needed this information. How does it sound. Are you going to get the rest of the intake , i.e. spacer and filter?
How is the quality are you happy with it ?
I really like doing DIY...... it feels very rewarding once the job is done (especially for a n00b like me) :laugh:
-mark
VERY NICE~~~
let's make a GROUP BUY!!! who's interested?! :banana:
the induction note is definitely louder as all the restrictive parts have been removed. you really only hear it in the upper rev ranges when you give it a bootfull....
as far as power goes, i really dont know cant tell. i already have a K&N Drop In Filter, i dont think i will spend the money on the popcharger etc. as when i get the supercharger it is pointless anyway
as far as quality goes, its pretty damn clean and nice. very well made.
the only gripe i have, is that the emissions tube is a bit further down and you have to like stretch the tube a bit further down, than where the stock item is placed. also you really need to stretch the accordian rubber parts in order to get a good fit, as IMO it doesn't line up as good as say the factory z tube.
-mark
Edited by BLISTC
Looks like you took out the resonator. Underneath the airbox correct ? Doesn't do too much, just quietens things down in terms of induction/engine noise.
I had mine blocked off but thought it hampered response, so unblocked it. I have no idea why, but maybe because the factory airbox design/flow relies on having the resonator there *shrugs*.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
