g'day folks
i am in the process of doing a number of performance mods to my rb25 det neo... i have spoken to my preferred engine tuner (uni group engineering giraween) and searched on here for what a good bov is to suit my car... the blokes at uni group told me that in order for the afm to function correctly, a plumb back blow off valve is required (no problem here i prefer not to hear the ptschhh)... upon searching on here for a decent blow off valve, i have come to the conclusion that the general consensus is that the gtr blow off valves are awesome and upgrading to an aftermarket one is considered a downgrade... also after searching i have found that gtr bov's are rare as hens teeth and when they come up for sale they are gone within days...
i have my standard blow off valve off my motor (r34 RB25 neo turbo) lying around... just wondering how much boost they can handle before they start having problems???
i guess the r34 blow off valve will suffice until i get a gtr one???
thanks in advance
The most cost effective BOV is the Bosch one used by Porcshe, Audi, Saab and now Ford in the F6...$70-$90 new...They won't win you any prizes at Autosalon (who gives a shit) but if you are after an effective 'compressor bypass valve' good for 15-20 psi that doesn't cost hundreds they are awesome...
Btw Zoom did a review on a few BOVs years ago and these came up trumps....
Why would you spend $70-$90 on a single item when you can get a GTR one for around 50-60?
They do the same job, hold over 370rwkw/24psi in single form (i've proven this on my own car)
And they leak @ idle like the stock item so you dont have AFM issues.
The choice is simple for Skyline owners - GTR BOV.
The Bosch ones are also 'held open' at idle so there is no idle issues...They also have hose tails on the inlet and outlet so there is no rooting around with welding flanges etc...
Sure I can spend time and chasing a GTR bov...I believe the quote in the previous post was 'rare as hens teeth though'..If I find one (which I will eventually) it 'may' be rooted...so the process starts again...I have never bothered chasing one up so I could be wrong...This just comes from 20yrs exp playing with cars...
OR I can pick up the phone and call my local Saab dealer and buy something brand new off the shelf that 'will work and work well' for a decent period...3 years my current BOV has been in service...No problems at all...
Now I am not saying that the GTR bovs are not the way to go...What I AM saying is that the Bosch ones are a decent option and will alway be easy to get...Its what I use and I have had great success...
Just trying to give the guy options thats all...
And a GTR BOV is change over with the stock... point?
As for 'rare' - Ive had some for sale for 2 months or so, on and off. Sold 4 sets so far and they dont get taken the day i post, takes a few weeks.
And over the past 3 weeks ive seen 4 other sets go up also.
They are not rare by any means of the word. If someone thinks that, they aren't even looking
Ok so what you are saying is that the GTR bov is a 'bolt on' to the stock GTSt intake pipe work?? In that case it is a good option 'if' you are running the stock pipe work...
When I was running the stock intake pipe work I gutted the stock GTSt bov and used it as an adpator only. I then plumbed the Bosch bov in place of the rubber hose bend that joins to the black metal pipe that goes to the turbo intake pipe...This made a noticable difference because the Bosch BOV sealing mechanism is rubber on a hard plastic seat
as opposed to the stock aluminium to aluminiuim (complete with the Nissan 1mm breather hole designed to make the GTSt drive a bit more smoothly so it appealed to the over 45yos as well ) ..I am assuming the GTR BOV is rubber on aluminium seat for it to seal better than the GTSt one...?
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
