  • Replies 53
Strich9ine, yeah the 4 door is an auto. Didn't get a chance to talk to you as you were pretty busy trying to sort out the coupe.
Got Boost , Don't pick on the sludge box! I like the auto's for the drags, consistant launch with a tourque curve that starts high ( good old stall converter :) ) and keeps steady . Oh & I REALLY thought I had ya when you broke traction ... bloody rb26 top end... :P
Originally posted by GTS-t VSPEC
rep003, That's good work, auto's are better than people give them credit for:D
Now you said that Paul theres no going back ....... i'll drag it up you said that quite frequently now :(
