You might be able to use the rear rotors of a R34 vspec 11 or 2001 on R34 GTR?, as they both run the larger rear rotor 324mm by memory,maybe machined down to suit
These bolt straight on to R32 and fit the existing handbrake,I have them on mine
When i was looking for rotors I'm pretty sure DBA dont sell the larger rears and Projectmu were the only option
Also while you can use tin snips to trim the guard I used a 100mm grinder with a thin cutiing disc.I wouldnt let a 9 inch anywhere near my ally hubs,those things should need a licence to use :)
Ronin what needs to be done to get the 350z rotors to fit?
You are making sense Ronin_09,
I guess they only way to really tell is to trial fit with a 316 x 20 rotor (if they exsist, I can't be stuff checking just now) to see if it fits...
Anyway, for those that are interested, below is the pics of the inside of the rotors.
BTW, front rotors have piston diameters of 40mm and 34mm and the rear rotors have a piston diameter of 30mm.
By way on comparison:
Bremo as fitted to R33's etc: 44 & 38mm dia pistons front, 40mm rear.
Sumitomo as fitted to R32's 40.4mm (all the same) front, 38mm rear.
So there is not much point using these WRX Brembos as they are too small in piston dia.
ronin's rear brakes are the 33/34 brembo calipers with Biot 3 piece rear rotors. fking awesome sexy piece of gear, but not for the light of wallet! I should know I sold it to him. :down:
http://www.biot.co.jp/parts_brake/offset_k...etkit_rear.html
ronin truly is the asse of biot:
So i guess that's pretty much /thread, but is upgrading the rears a wank anyways? Risking told me that even with the standard rears and something like 360mm + chunky calliper at the front, he still has too much rear brake bias on his race car (or is that a special case)...
I have heard that too,yet no one seems to complain about the bias on the std 32 brakes and the rears are bigger than the front.
Bit of a strange question but how do you pronounce Biot?
Is it buy-ott or Bee-ohh :woot:
thanks
  • 3 months later...
I am going to revive this thread as I have recently purchased a set of 05 STI callipers (front and rear) + rotors and will adapt it to my R32 GTR.
I will try to detail everything from additional parts to issues (and solutions) with installation and labouring costs which hopefully will help other people going down the same path.
I think this can be a successful alternative to purchasing other brembo brakes such as the R34 and R33 GTR brembos.
I am running 17inch BBS LM wheels with standard sumitomos but not for long.
Watch this space.
  • 4 weeks later...
Watch this space.
I also have a 94 R32 GTR and was wondering about fitting STI brembo calipers to the rear of my car. I have new rear Nissan Brembo rotors (300mm) and thought I could use those with the STI caliper, but reading this blog maybe not?
I hadnt thought of using STI calipers on the front. They certainly seem to be cheaper to buy than the equivalent Nissan Brembos.
I have new 328mm rotors for the front as used on the V Spec, so was looking for a dogbone that would allow the use of the standard GTR caliper with the upsized 328mm disc - does anyone know if these dogbones are available any where?
However if the STI calipers will go on the front with say a 355mm rotor that would be good. Please let us know how you go
regards
    • Kinda glad I never got to this ..    https://www.facebook.com/groups/1483859159195077
    • @GTSBoy This method was able to get readings of -10 to -2, so it looks like its monitoring.  Now I need to figure out why the vacuum on the line provided isn't alternating with manifold pressure.  I went with 2 lines that an RB25 tuner recommended but I'll get a longer hose and try directly off the back of the manifold.  He may have been used to OEM intake setups while I have a DBW setup that removed the MAF and IACV.
    • I work at a car detailing and tinting shop called Quark which gets all manner of German cars in usually (mainly due to a contract with Mercedes Benz Kita Osaka, BMW Nishinomiya and others) but every once in a while something special comes in, like a fully restored 1972 HS30 Nissan Fairlady 240ZG... The shop owner had immediately started applying film to the windows as soon as it was in the shop so the interior was completely covered in towels and plastic sheets. But I could get a few photos of the engine bay which was restored like new. Such an amazing car to see in pristine condition in Japan these days.
    • Was going to say the car pulls up nicely everywhere, especially going into that last long right hander before the main straight. Looks like a lot of fun.
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
