Where can i buy one!!! I have searched far and wide and every aussie shop I find has a disconnected number. Currently my best bet is america.
any ideas for a locally stocked meth kit? Just really need a pump, controller and one way check valve..
https://www.sau.com.au/forums/topic/260848-water-meth-kits/
I tried to call them!!!!! said the number was disconnected. I also sent a email a few weeks ago, to no reply :/
Dude they are still trading...I spoke to the guy the other day..They have moved to WA I think...Have a search on their website for a mobile number...It gets through to them...Can't remember where I found it but its there somewhere....
https://www.sau.com.au/forums/topic/260848-water-meth-kits/#findComment-4474396
Have you talked to RDP leon?
I think brock said something about water meth, otherwise it was CO2 or something. But they can probably do water meth as well, worth an ask
Hey,
Nah i havent actually. Spoke to Trevour at adrenaline and he has 2 kits on order but they are sold already for customer. Could you please pm me Brocks number, ill message him.
https://www.sau.com.au/forums/topic/260848-water-meth-kits/#findComment-4474406
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
